+ 1 Thank you.
I have run into the Fat 32 naming problem, but as of Tiger the Mac OS gives one a warning why it can't be copied to Fat 32.
Hugy if a sample like Alicia Keys (12 gigs and 11 layers) at 44.1k. I was trying to figure how much loads into ram. Say 4 notes per single sample... so that's 22 distinct samples with 11 velocity layers on an 88 key piano. With my E4 it loads the entire sample into ram. If the Mach 5 is streaming and ram is flushed regularly...
At any one time how much ram can be used for a large sample like this?
So how can i convert all the cool sampler formats?
Re: So how can i convert all the cool sampler formats?
Something like 600Mo I would say.
I would check the size taken by the full Telematic preset, it should be around the same size given the specs.
FWIW NI Alicia Keys won't load in M5.
M5 do not import Kontakt script and Alicia Keys is a protected soundbank which is not supported by M5 as well.
