Reverse Plug In and Reverse Phase not in DP 7.22?
beautypill
Re: Reverse Plug In and Reverse Phase not in DP 7.22?
Post by beautypill »
I am having this problem now as well.
"Motu: Invert Phase" and "Motu: Reverse" plug-ins are suddenly gone.
What is the solution? Did anyone find one?
- c
They're gone from the plugin folder as well?
barreltone
Post by barreltone »
beautypill wrote:"Motu: Invert Phase" and "Motu: Reverse" plug-ins are suddenly gone.
What do you mean by "suddenly"? Did you just newly install DP 7, as the OP did, or did you recently update to 7.22, or just poof?
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
beautypill
I was helped by a friendly Motunation person here as well as MOTU official tech support and the problem is fixed.
I don't know when precisely the plug-ins disappeared... maybe when updated to 7.22? Not sure.
Anyway, problem solved now.
- c
And the solution was...?
beautypill
They mail you the plug-ins again and you install them.
Something about updating to 7.22 seems to remove them, I think. Not sure. I know I certainly never manually removed them.
My advice: Contact MOTU support, they seemed to be familiar with the issue.
- c
Thank you for posting that.
Mine are still intact. Don't know what causes it to happen to some people's systems.
tommymandel
Post by tommymandel »
Reverse and Invert Phase plug-ins are still present in both my laptop and desktop systems. 7.22. Installed from downloaded update file.
DP 11.32 12core(5,1): 64GB/10.14.6, two 24i/o's, two 2408mk3's, 4pre, MicroLite-- MBP 2015 16GB/ 2TB 'Blade SSD 10.14.4, Mainstage, Numa C2x, ReMOTE SL -- 32 Lives, Pro-53, SampleTron,Keyscape,MTronPro,RolCloud,Icarus,Dune,OB-E; Clearmountain Domain,Soundtoys,AdrenaLinnSync, LinnSequencers,Tempest, Montage, JU80, Sledge, Prophet-X, T8, OB-6 V-Synth, s70xs, D-50, TS-10, JD800, Karma, Pa-1x B3, Wurly, Mason Hamlin.
barreltone
hey beautypill, had you created folders within your MAS plugin folder, to organize your MAS plugs? That's the only thing I can think of that would possibly cause an update to burp for you, but not for tommy above.
Could be a multitude of things I'm too stupid for, though! :)
LVB1110
Post by LVB1110 »
Hi All,
Hoping someone can help me with the same issue. My Reverse Plug In is missing from the Audio Plug Ins in the Audio Dropdown Menu. When I checked in Preferences though, I can see it listed there. When I contacted MOTU they were totally unhelpful. I was told they don't support earlier versions of DP with OS 10 or later, and that if I wanted help I would have to upgrade to DP 9. I'm in the middle of a film score and don't want the headache of having to learn a new version, not to mention having to spend almost $200 just to get a reverse plugin running.
Any suggestions would be super appreciated! Thanks guys!
*I'm running DP 7.24. My OS is 10.11
You can check your MAS folder
Root Library/Audio/Plugins/MAS
to see if the reverse bundle is in there.
You can do a reinstall over your current install just see if it will replace the missing plugin. You could get into some DP prefs trashing, but I'd try the above first.
As a workaround, you could use freeware like audacity to reverse your audio then reimport.
Don't trash the Preferences. Don't reinstall over. There's a correct way to rebuild the paths to your plugins in DP .7 and that's with a complete uninstall and reinstall. Takes about 5 minutes.
viewtopic.php?f=1&t=62032
If you have a 7.24 CD, you run it from the CD only.
True, DP 7.24 is no longer supported but it works fine.
After you reinstall, you will get a QuickScribe message—it's not an error. You mmake it go away by right-clicking on the app, Show Package Contents/Contents/Resources/QuickScribeX. Click on Install Font and you're good.
David Polich
Post by David Polich »
Btw...if anyone is wondering how to find the Reverse plug-in in DP 9.02, here's how:
In Tracks IOverview window, select and highlight an audio track.
From the Audio Menu, choose Apply Plug-In...
This opens the Apply PlugIns menu (which is not the same as the menu that opens when you double-click on an insert slot in the mixing board).
You can choose MOTU on the left and then on the right side you'll see the list of available plug-ins, including Reverse.
This brings up an issue I think MOTU should address. The Reverse plug-in should be available in the plug-in menu when you double-click an insert slot. I really have never understood why it is only available in the Audio Menu Apply Plug-Ins menu.
http://www.davepolich.com
Kurt Cowling
Post by Kurt Cowling »
Reverse requires a time selection and to create a new soundbite. You can't reverse audio in real time. That's why it isn't available as an insert.
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
