AAF/OMF import to DP6
gref
AAF/OMF import to DP6 ---> Use Audiodesk!!!
Post by gref »
Ok, if you also have Motu hardware, you should have Audiodesk. By using Audiodesk 2.11 I could easily open an OMF2.0 and make an Audiodesk project with that.
This can be opened in DP6 and be saved as a DP project… voilà!
Hope it works for you too!
HAPPY HAPPY JOY JOY :D :D :D :D :D :D
Homeediting is killin proToolstitution…
apanacci
Re: AAF/OMF import to DP6
Post by apanacci »
Hey guys I finally opened an OMF with an old vers still installed. I used DP 4.6 saved it as a DP session then opened it in 6. Worked fine!
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
