plug-ins & vi's that are not working with dp6
RecordingArts wrote:As soon as I got rid of the 1.22 version in my master channel and replaced it with 1.3 all was well!!!!
Thanks for the custom tech support James!
No need. You were the one that figured out what was going wrong. I might never have found it because I'm illogical/lazy enough to just throw up my hands in that situation and chalk it up to the ghost in the machine and not investigate further.
Eleventh Hour Sound
Post by Eleventh Hour Sound »
That's what I love about "The Nation" though. It makes me think:) Just hearing that yours worked made me look a little harder.
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
Killahurts
Post by Killahurts »
Sonnox Sony Oxford Dynamics plug does not work in DP 6 and just installing DP6 will break the thing from working in 5.13 as well.
I had to uninstall 6, AND reinstall 5.13 to get it to work again.
I wrote a thread about it here somewhere..
daveyboy
Post by daveyboy »
Killahurts wrote:Sonnox Sony Oxford Dynamics plug does not work in DP 6 and just installing DP6 will break the thing from working in 5.13 as well.
Too bad you did a whole reinstall. We should have a sticky about the broken AudioUnit Support.bundle so that folks know the work around. Seems like a big one to me. James, what say you?
Dave
www.dbwproductions.com
Rusty Shackleford
Post by Rusty Shackleford »
Does Atmosphere, Trilogy and Stylus RMX work in DP6 on a PPC? Thanks.
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
Killahurts
Good idea! In the meantime, what is the workaround? :)
chrispick
Post by chrispick »
I switched out the 6.0 AU support bundle for the 5.13 one, and all of my VIs and plug-ins are running perfectly in 6.0.
I had the privilege of finding this temp fix here on the 'Nation before I installed 6.0. So, before I loaded it up, I saved the 5.13 bundle to another drive, then slugged it in after.
If the 6.0 support bundle was advanced only to allow prerendering, I'm fine removing it. I prefer to work without prerendering anything. No unexpected audio pops.
I should say: Since then, I've only given 6.0 a quick one-hour test drive, but it held up perfectly.
carrythebanner
Post by carrythebanner »
chrispick wrote:If the 6.0 support bundle was advanced only to allow prerendering, I'm fine removing. I prefer to work without prerendering anything.
It's probably required for the other AU enhancements: ramp automation, sidechain inputs, Cocoa UIs, etc.
chrispick
Post by chrispick »
Ah, yes. You're probably right. Well, I kept the 6.0 bundle on my system. Should I need to switch it back in, I can roll the dice.
kwiz
Post by kwiz »
Sound Toys bundle: knobs won't turn at all.
Also, bounce to disk crashed several times on a 26 track project.
I ended up saving the project in 5.12 and then opened DP 5 in order to BTD.
Great family and friends!
F. Douglas
labman
Post by labman »
chrispick wrote: I switched out the 6.0 AU support bundle for the 5.13 one, and all of my VIs and plug-ins are running perfectly in 6.0.
Can you please lis all your plugs and V.I.s Chris. Thanks so much.
Regards,
DLevy
mgr, Legacy Lab
mongoose
Post by mongoose »
Just to update: there was a post on another thread that noted VI failure only when the GUI was opened in DP6; I tested this and got the same results.
If I make a project with VIs like B4II or M-Tron using the old AU MAS bundle to set them up, and then open them in DP6 using the new AU MAS wrapper, everything is hunky dory until I open the GUI. Then DP crashes.
All of these various reports suggest a problem with handling the GUI on AUs in DP6. I've filed (and revised multiple times) a report with MOTU tech support; my understanding is hat others have done so as well. Hopefully we'll see some response.
Spankin' 2020 10-core iMac, 40GB, Catalina, DP 10, Ivory, B-5, M-Tron,
UAD-2, Wissner Artist Upright Grand, Tokai MAT Strat, P-Bass, and a bunch of other noisemakers.
homebilly
Post by homebilly »
MachFive version 2.0 (the version that reads the Trilogy & Atmosphere .dats) works.
there are some graphics anomalies though....
http://www.ronmeza.com
Keystation 49e controller
chrispick
Post by chrispick »
labman wrote:Can you please list all your plugs and V.I.s Chris. Thanks so much.
Sure.
VIs:
alphakanal Automat
FabFilter Twin
iZotope iDrum
Rob Papen Blue
Spectrasonics Atmophere (via wrapper)
USB Plugsound Pro
MicroTonic
fxpansion BFD
NI B4
NI Massive
NI Kontakt 2
Plugins:
AudioEase Altiverb 6
FabFilter Volcano
iZotope Ozone
iZotope Vinyl
Massey Tape Head (AU deal)
Voxengo VariSaturator
WaveArts TrackPlug
Sonalkis FreeG
Antares Auto Tune 5
Audio Damage Dubstation, Liquid and Reverence
NI Guitar Rig 2
PSP MixPack and VintageWarmer
UAD-1, nearly everything they offer
Tested them all. Printed to file. Bounced quick mix to HD. Successful on all counts.
dp-user
Post by dp-user »
I'm not sure what the difference is, but for me, all the NI plugs work fine in DP6 (using the DP6 Mas AU support bundle, not the older one). In fact, I have yet to find a plugin that doesn't work in DP6...
The very first time I tried an AU insert effect, DP6 did present an error message, but then I selected a different effect, which came up, and then selected "Reactivate Effects" from the mini-menu in the effect editor, and I was able to load the effect I tried to load the first time. I haven't seen this issue since...
Other than that, everything's fine. It would be interesting to know what's different between our setups...
MBP 2.33GHz, 2GB RAM, OSX 10.5.4, QT 7.5, DP6
