Tiger Compatibility List
aeser
Re: Tiger Compatibility List
Post by aeser »
kontakt 2, reaktor 4, peak 4, and moog modular V all work
macbook pro (thunderbolt), DP7.22, NI komplete
chaim
Post by chaim »
Is the folowing working:
Alti Verb '4'
Vst Wrapper 4.1.3
Thanks.
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
hammerman
Post by hammerman »
I'm having no problems with Altiverb 4 with Tiger. Man, I haven't had DP crash ONCE yet with Tiger!
M2 Mac Studio Ultra - 64 GB RAM - Sequoia - DP 11
chaim
Post by chaim »
Thanks.
Plaz
Post by Plaz »
I'd been putting off the upgrade from DP 4.12... this has forced my hand.
DP 4.12 is definitely not Tiger compatible on my system.
4.5 ordered.
maintiger
Post by maintiger »
the only version of DP that is tiger compatible is 4.52- so buy 4.5 and then upgrade to 4.52
Xavier Calvera
DP 6 dual G5 2.0- 828mkii-
apogee rosetta - Mach Five, Atmosphere, Stylus, Garritan, Soundtrack,
more soft synths...
check out my latest DP project at www.theorishasarecoming.com more on www.lordtiger.com
toodamnhip
Post by toodamnhip »
Ivory graphics weird since Tiger update.
Processor spike create audio drop outs since Tiger update...
Really pisses me off!
MOTU said it might be plug ins and advised changing disk read/write and buffer to 200; up from the 150 default.
But as usual, it's kind of the same old "don't know exactly what's going on, probably other plug ins" answer.
Anyone else have processor spikes?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
RCory
Post by RCory »
There is an Ivory update for Tiger...
check previous post for link to download...
it's not MOTU's fault..
toodamnhip
We'll see if it's not MOTU's fault..I hope you're right. Thanks for the Ivory update info...
I'll post results as soon as I load it
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
maintiger
Post by maintiger »
can we run atmosphere with a vst wrapper under tiger? I just ordered a new G5 and I need my atmosphere... :confused:
Xavier Calvera
more soft synths...
dacart
Post by dacart »
I use all the Spectrasonics stuff under VST wrapper and have had no problems with Tiger. Unfortunately I leapt in before noting the UAD-1 incompatibility so... pooh.
Dan Carter
"Ted, you know the way you are? Don't be that way!" Lou Grant to Ted Baxter
maintiger
Post by maintiger »
are you using the audio ease vst to mas wrapper?
Xavier Calvera
more soft synths...
Sergievsky
Post by Sergievsky »
How did you upgrade to Tiger? I'd like to not have to re-authorize everything...does the "upgrade" method work? I usually prefer to wipe everything and start clean when installing a major new OS, but this time not sure I wanna do all the authorizing again.
Raul
iMac Pro 3GHZ 10-core, 128GB RAM, 2TB hd, Big Sur
motu 8pre-es
