Page 2 of 2
Posted: Sat Mar 01, 2008 9:15 pm
by pcm
OortNYC wrote:Thanks for the info.
Does DP do AAF transfers? Any benefit to that over OMF?
AAF (at least in DP) will not allow "references" to soundbites, it forces you to allow a full copy of the audio data. That is much wasted space! All I want is the OMF document. I then drag that onto the PT icon in the doc. PT then creates a new session FROM the references.
I use AAF coming out of Logic, however, as Logic will not export volume automation with OMF, but will with AAF.
Posted: Sat Mar 01, 2008 9:18 pm
by OortNYC
I tried AAF but got an error in PT on import.
I am trying OMF now but cannot get PT to see Mixer Volume and Pan settings. I tried taking a snapshot.
Thanks for all your help - much appreciated.
D -
Posted: Sat Mar 01, 2008 9:20 pm
by OortNYC
Also - is there a way to bring a stereo DP track into a stereo PT track?
It is bringing it in a 2 mono tracks.
Thanks -
Posted: Sun Mar 02, 2008 11:26 am
by pcm
OortNYC wrote:I tried AAF but got an error in PT on import.
D -
Pan settings won't transfer. Not sure what you are doing wrong as far as the volume automation goes, but that definitely works.
Posted: Sun Mar 02, 2008 11:29 am
by pcm
OortNYC wrote:Also - is there a way to bring a stereo DP track into a stereo PT track?
Thanks -
You have to fix that manually.
Posted: Sun Mar 02, 2008 11:39 am
by OortNYC
Thanks -
I got it going. Was not used to having PT faders slowly moving to the automation point. Used to DP of just snapping. Surprised about the pan settings. I tried it with AAF files but its the same.
