So THAT was it? A stupid slash sign??
Who would've thought...
Glad you got it working!!
How did you feel after you found the culprit??
Thanks! I feel relieved, considering I need to have this project to the client by 11am tomorrow!FMiguelez wrote:.
So THAT was it? A stupid slash sign??![]()
Hey, we're related! My last names are also We Todd It. My first name is Sofa King. Yes, I'm Sofa King We Todd It. Glad to meet you, brother.gregwhartley wrote:Okay, sorry guys. My name is not gregwhartley, it is We Todd It.
Yes, perhaps we are! I am We Todd It, son of Mike Hunt and Mona Lott. Good to finally meet you, sir!Shooshie wrote:Hey, we're related! My last names are also We Todd It. My first name is Sofa King. Yes, I'm Sofa King We Todd It. Glad to meet you, brother.
Shoosh
Yes, I've been there as wellpcm wrote:Don't use periods (.) either. OSX will sometimes mistake what comes after it for a file extension.
PCM:pcm wrote: If you have a newer motu interface, you can create a new audio track, and select it's input as "MIX1". Go into Cuemix, and under the File menu, make sure "MIX1 Return Includes Computer Output" has a check next to it. Once that is set, it will stay set. Now, when you arm that track, it will record everything that you are hearing on your speakers. That means all audio tracks, VIs, outboard aux returns, everything.
This only works with firewire interfaces.buzzsmith wrote:PCM:pcm wrote: If you have a newer motu interface, you can create a new audio track, and select it's input as "MIX1". Go into Cuemix, and under the File menu, make sure "MIX1 Return Includes Computer Output" has a check next to it. Once that is set, it will stay set. Now, when you arm that track, it will record everything that you are hearing on your speakers. That means all audio tracks, VIs, outboard aux returns, everything.
How new is new?
I have 2 2408s and a 24i and I don't see the option for "Mix 1" as an input...I also don't see in Cuemix (v 1.4) under "File" the "MIX1 Return Includes Computer Output".
Buzz
