Interesting F-chart
- vbassguy
Thank You!
G5 quad 2.5 ghz w/ 8 gigs ram, OS 10.5.4, DP 5.13,DP6, Mach 5,Mach 5 v2, SI, two loaded UAD-1e cards, PCIe 424, two Black Lion Modded 24 I/O's, Harrison 3624 console, cool old mics, pre's and compressors.....Great sounding Rooms.........
www.RRRPROD.com
www.RRRPROD.com
- vbassguy
Thank You!
www.RRRPROD.com
www.RRRPROD.com
you are all welcome guys ![Wink :wink:](./images/smilies/icon_wink.gif)
I am a very happy DAD.
MacPro 3.33Ghz 6core-32g Ram-10T HDs-10.12.6-Dp-10.0.1.
Korg Kronos 2-Korg Pa4X-Ensonic TS 10-Korg T3-Yamaha Dx 7iiFD-Akai S3000xl-Roland JV 2080
Genelec 1031A with KRK 10S sub-Yamaha NS10m
ULN-2..Tubetech Lca2B-Avalon 737sp-HEDD 192-Lexicon PCM 90.
Soundcraft Sapphyre 28ch
MIDI Life Crisis wrote:Save it as a "archive" in Safari and you can get access to all the data offline.Shooshie wrote:... I tried saving it as a PDF, and the basic chart will save that way, but the active parts of it come out empty...
Sure, but then you have to open it in Safari, which defeats the purpose of the PDF to begin with. It's no big deal; one can just open the link in Safari and have it, but I like to have things on my drive that can't be obsoleted by the removal or "improvement" of a website. In this information age, nothing on the internet is permanent, and most of it goes away within 5 years, if not sooner.
Plus the rollover links only work if they're still live and you're online. It would be great to be able to save a "once removed" archive that includes all first-generation links...Shooshie wrote:MIDI Life Crisis wrote:Save it as a "archive" in Safari and you can get access to all the data offline.Shooshie wrote:... I tried saving it as a PDF, and the basic chart will save that way, but the active parts of it come out empty...
Say, I WAS able to save it as a widget in Dashboard. Using the File menu/Open In Dashboard, it created a rather large widget that's about 70% operational. You have to double-click on the instruments instead of mousing over them, and the spectrum rollover stuff does not respond at all, but it's better than the PDF attempt. Of course... you have to open it in Dashboard.
Tonio wrote:Glens' freq chart is definately in my fav's bookmarks.. He's very knowledgable on compression too.
T
If you know this guy, see if he will post it as a standalone Java or Flash module.
Shooshie,
It does list the loudness curves as ISO 226:2003. If you open the loudness curves there is a text box up at the top. Hit the next button and it tells you what curve was used. I just stumbled on it.
Bg
Bg
Brian Green
Castlebury Productions
Franklin TN
MacPro Quad Core 3Ghz, 10.7.5,
7GigRAM,DP 6.03,Logic 9.1.8,Macbook Pro 2.0,2gig, 2408mk3,2408,Traveler,O2R96,O3D,GIGA,Muse Receptor,Various VI's and plug ins
Franklin TN
Glen has plans for an applet sometime this year as captioned:
1tonio,
I do have general plans to hopefully offer each of the online resources available as stand-alone applets sometime in the near future, perhaps later this year. The exact plans and schedule for this are yet to be determined, though; I have several new expansions to the IRN website under development at the moment that I have to get up and running first. Stay tuned...
G.
Anyone check out his compression article? Good stuff
http://www.independentrecording.net/irn/ link on the right.
T
1tonio,
G.
T
- toodamnhip
Nice Chart...MIDI Life Crisis wrote:Save it as a "archive" in Safari and you can get access to all the data offline.Shooshie wrote:... I tried saving it as a PDF, and the basic chart will save that way, but the active parts of it come out empty...
Great stuff, BTW! Thanks.
I have a question..
When you save a web page as a web archive, does it need the web to re load in the future? If the site goes off line, will the web archive still work or go to a dead link?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Someone will correct me if I'm wrong (and even if I'm right) but if he is using an embedded script and the script is included in the archive, I believe you DO NOT need to access the site, you only need to open the file in a program that can read the file and the script IE- a browser.
There was an earlier objection to that and they wanted the PDF. I tried the widget thing from Safari as well, but that was just too geeky and just plain ugly to me. I archived the file in case the program went down, but frankly, I have a few other resources to advise me about instrument ranges, etc. The frequency data might be useful for creating anal retentive stems (which some editors seem to enjoy).
There's a lot of good stuff to learn at that site. I'm just not sure it will make my orchestrations any better.![Smile :)](./images/smilies/icon_smile.gif)
