G5 Surround and DP
Digital Perfomer in the context of television/film scoring and post-production.
martian
Post by martian »
I did try the following steps as advise by mofo tech support
change the video file - ( redigitise or transcode )
throw away analysis and fades...
Compact projects...
If you suspect a corrupt audio file -
I have had success with files crashing on opening - use sound grinder to transcode from sd to wav and back again - it has a useful option whereby the names will remain identical.
a similiar effect can be done in DP by exporting OMF's and make it recreate all files that way...
PS make sure you write to motu with this issue - they claim I'm the only one...
weird thing is it tends to be 1 file in 5 that goes this way,... - other projects have no issues...
I was working with DP for 12 hours today and not one crash... but some days grrrrrrrrrrrr
macpro 3 gig - 5 Gig RAM 10.6.3 Motu 2408 mk 2 Mackie HUI DP 7.21 intel imac 3 gig ram traveller OS 10.6.3
http://www.fork-media.com
dubbeljee
Post by dubbeljee »
Hey,
thank you all for the reply's i've been away for a few days
I 'm also thinking it has something to do with incompatible plug ins
however I made my project template including all plugs before I even started
merging soundbites is just not a right idea in my opinion
changing the save command is a good idea I haven't thought about.
JJ
martian
Post by martian »
yeah me too - I use a project which I then save a copy as and duplicate audio ( even tho there isn't any)
this is better than the the template - I can set up things like all the insert automation....
( I use 3 different verbs usually - and find it very boring to insert send a, etc....)
dubbeljee
Post by dubbeljee »
To answer auptowns questions.
I'm running DP 5.11, G5 DP 2,3 Ghz 2 GB ram altiverb 5, Motu 828II and some outboard wich makes it impossible to use the onboard soundcard.
my project runs from one single drive, First the internal and I have my BU drive connect to FW 800 together with an other FW800 drive wich contains my sound library
later I switched to the First FW800 drive as my work disk and the internal as a BU disk
and synchronize them mannualy every 10 minutes
JJ
