DP 8.05
artfarm1
Re: DP 8.05
Post by artfarm1 »
Working beautifully on Intel 2 Duo Core 6 gig RAM.
Less CPU hit, and the new MachFive 3.2 is just as smooth running too.
Way to go MOTU! New life for my old machine!
DP 11, OS Ventura
MacMini 2023 M2Pro, 16 gig RAM, MOTU M6, SSD drives for everything, various sound/sampled libraries from all major vendors, Logic Pro X, DSP-Quattro
MacBook Pro 2015, OSX Monterey, 2.5ghz, 16 gig RAM (w/duplicate software as in MacMini setup)
Trombones: King 2B SilverSonic, King 2B Liberty, & Conn 88H w/Doug Elliott mouthpieces!
http://www.cammillarmusic.com
wheever
Re: DP 8.05
Post by wheever »
Uh, welp, I installed 8.05 and proceeded to have a terrible and crashy day, although things seemed to draw faster on the screen. Now, how do I go back to 8.04? :roll:
Performer user since--HOLY CR*P--1986? YIKES!
Re: DP 8.05
We might have some comments if you had included your setup in your sig.
Re: DP 8.05
wheever wrote:Uh, welp, I installed 8.05 and proceeded to have a terrible and crashy day, although things seemed to draw faster on the screen. Now, how do I go back to 8.04? :roll:
If you want to try and see if we can help, post details of what was happening and your setup.
Re: DP 8.05
Easily - but it helps know your setup to point you in the right direction. Knowing what "broke" also helps.
You can restore a single application via Time Machine. It will ask if you want to replace the new version with the old or keep both. It is a little known but very cool feature. Tech Support at MicroMat taught me that trick when a new version of TechTool Pro didn't work properly on my iMac and the old version could not be downloaded.
Phil O
Re: DP 8.05
Post by Phil O »
When I first got 8.05, I had several problems. A re-install cleared everything up. I'm not saying you have a bad install, but I did. Reinstalling might be worth a try.
Phil
Steve Steele
Re: DP 8.05
Post by Steve Steele »
Before I update to a new version I rename the old version DP 8.04. I've got all of the 8x releases just in case.
Mac Studio M1 Ultra, 128GBs Unified memory, 4TB SSD.
Interfaces: MOTU M2 and 8A (2.1 and 5.1 setups).
DAWs: Digital Performer 11, Logic Pro, Cubase 12 Pro, Studio One Pro.
Sample Libraries: Primary - VSL (all), Spitfire, (mostly all), and many others.
External Controllers: Metagrid Pro and Studio Logic SL|MIXFACE
Re: DP 8.05
I just use Time Machine.
wheever
Re: DP 8.05
Post by wheever »
Thanks guys, but I really wasn't looking for help as much as just venting. 8.04 didn't crash at all on the same sequences. Nothing else in my config changed between the two versions.
However, just for the sake of explanation, the two crashes I kept getting most consistently yesterday were when I would try and change the buffer size, and when I would try and drag an effect insert. (Usually MW EQ.) The error for the effect insert was something about "bad alloc" but would disappear too quickly for me to see it. Crash logs were unhelpful for anything else. I don't really have time at the moment to dig around and see if I can figure it out, and really the easiest thing would just to back out to 8.04. Usually I keep renamed versions, but for whatever reason this time I didn't. :roll: Sigh.
Re: DP 8.05
I hope when it crashed you got the dialog that asks if you want to send a report to MOTU and went ahead and sent the report. MOTU now has a crash reporter that sends the info to them and that may help them solve it. It's no consolation I know, but I'm not seeing that here. :(
Just wondering but have you tested RAM with something like Rember? Not likely it's your issue, but I've had RAM go bad and one of the symptoms in general flakiness and instability. :(
Re: DP 8.05
Repaired permissions? Reset PRAM?
Both can possibly fix this.
Re: DP 8.05
As I mentioned, Time Machine can restore 8.04 - either replace 8.05 or have both up, your choice. 8.04 is still available for download, too.
But we still don't know your setup so if there's anything specific that we can point to and say, that's probably it, you might try..., we won't know it.
This is why we have our setup as part of our signatures; not because we are bragging. It really does help.
Re: DP 8.05
Oh yeah. I'm bragging about a 5 year old machine... actually, it's a very sweet machine. :)
mhschmieder
Re: DP 8.05
Post by mhschmieder »
Is that Food Art or Play-Dough?
toodamnhip
Re: DP 8.05
Post by toodamnhip »
DP 8.05 seems to be hanging on shut down for me WAAAAY more than 8.04 did.
I am using it in conjunction with Ve Pro too so I am not sure if that’s an issue?.
The start of Crash report below after force quit:
Date/Time: 2013-10-28 04:13:09 -0700
OS Version: 10.6.8 (Build 10K549)
Architecture: x86_64
Report Version: 7
Command: Digital Performer
Path: /Applications/AUDIO APPS/MOTU APPS/DP 8.05/Digital Performer.app/Contents/MacOS/Digital Performer
Version: 8.05 (8.05)
Parent: launchd [158]
PID: 245
Event: hang
Duration: 5.02s (sampling started after 2 seconds)
Steps: 10 (100ms sampling interval)
Pageins: 19
Pageouts: 0
Process: Digital Performer [245]
UID: 501
Thread d7c DispatchQueue 1
User stack:
10 std::__1::deque<short, std::__1::allocator<short> >::__add_back_capacity(unsigned long) + 2281 (in Digital Performer) [0x100a5dd79]
10 std::__1::deque<short, std::__1::allocator<short> >::__add_back_capacity(unsigned long) + 2506 (in Digital Performer) [0x100a5de5a]
10 _ZNSt3__16vectorINS_4pairIP7glogReciEENS_9allocatorIS4_EEE6insertENS_11__wrap_iterIPKS4_EEOS4_ + 42977 (in Digital Performer) [0x100878371]
10 RunApplicationWithDelegate(int, char**, std::__1::auto_ptr<MOTUApplicationDelegate>&) + 274 (in OSFoundation.dylib) [0x101dd5102]
10 NSApplicationMain + 364 (in AppKit) [0x7fff812223b0]
10 -[NSApplication run] + 474 (in AppKit) [0x7fff812296de]
10 RunApplicationWithDelegate(int, char**, std::__1::auto_ptr<MOTUApplicationDelegate>&) + 2846 (in OSFoundation.dylib) [0x101dd5b0e]
10 -[NSApplication sendEvent:] + 3630 (in AppKit) [0x7fff812926b9]
10 -[NSApplication _handleKeyEquivalent:] + 559 (in AppKit) [0x7fff813c1bed]
10 AdjustLightness(HSLAColor const&, double, double) + 1175 (in OSFoundation.dylib) [0x101e11b27]
10 -[NSMenu performKeyEquivalent:] + 272 (in AppKit) [0x7fff813c2e45]
10 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 121 (in AppKit) [0x7fff813dd1d4]
10 -[NSMenuItem _corePerformAction] + 365 (in AppKit) [0x7fff813dd46a]
10 -[NSApplication sendAction:to:from:] + 95 (in AppKit) [0x7fff813b8eda]
10 -[NSApplication terminate:] + 325 (in AppKit) [0x7fff8148c542]
10 -[NSApplication _shouldTerminate] + 351 (in AppKit) [0x7fff8148c91d]
10 -[NSDocumentController(NSInternal) _shouldTerminateWithDelegate:shouldTerminateSelector:] + 1207 (in AppKit) [0x7fff8148cf50]
10 -[NSDocumentController(NSInternal) _continueTerminationHavingClosedAllDocuments:context:] + 184 (in AppKit) [0x7fff8148d145]
10 -[NSApplication _docController:shouldTerminate:] + 83 (in AppKit) [0x7fff8148d5c8]
10 RunApplicationWithDelegate(int, char**, std::__1::auto_ptr<MOTUApplicationDelegate>&) + 6422 (in OSFoundation.dylib) [0x101dd6906]
10 OS::EventImpl::DispatchToApplication(UIEvent, boost::optional<MotuOSWindow::OSWindow&>) + 272 (in OSFoundation.dylib) [0x101e23dc0]
10 AppEventFilter::HandleUIEvent(UIEvent&) + 161 (in PerfFoundation.dylib) [0x1028e47f1]
10 IdleOnExit::~IdleOnExit() + 21 (in OSFoundation.dylib) [0x101db2d25]
10 CIdleChore::IdleAndReturnNextIdleTime() + 1321 (in libMotuCoreLibs.dylib) [0x10140bb09]
10 std::__1::vector<ChainOfCommand::HandleBeforeCommands*, std::__1::allocator<ChainOfCommand::HandleBeforeCommands*> >::vector(std::__1::vector<ChainOfCommand::HandleBeforeCommands*, std::__1::allocator<ChainOfCommand::HandleBeforeCommands*> > const&) + 390 (in DPBasicUI.dylib) [0x101772076]
10 ChainOfCommand::Chore::Run() + 173 (in DPBasicUI.dylib) [0x101771a9d]
10 RequestHandler::HandleCommand(RequestHandler*, CommandSpecifier const&, CommandActivator const*) + 94 (in DPBasicUI.dylib) [0x101765dfe]
10 NonSeqDocModelessGlog::HandleCommand(CommandSpecifier const&, CommandActivator const*) + 60 (in DPBasicUI.dylib) [0x1017826ac]
10 Application::HandleCommand(CommandSpecifier const&, CommandActivator const*) + 18 (in DPBasicUI.dylib) [0x101787a62]
10 _ZNSt3__16vectorINS_4pairIP7glogReciEENS_9allocatorIS4_EEE6insertENS_11__wrap_iterIPKS4_EEOS4_ + 18937 (in Digital Performer) [0x100872589]
10 _ZNSt3__16vectorINS_4pairIP7glogReciEENS_9allocatorIS4_EEE6insertENS_11__wrap_iterIPKS4_EEOS4_ + 21291 (in Digital Performer) [0x100872ebb]
10 std::__1::vector<unsigned int, std::__1::allocator<unsigned int> >::__append(unsigned long) + 8198 (in Digital Performer) [0x1002212c6]
10 SCSX_ControlSurface::Finalize() + 13 (in EuCon) [0x13e513967]
10 (anonymous namespace)::Terminate() + 25 (in EuCon) [0x13e51470d]
10 EuphonixSurface::Destroy() + 30 (in EuCon) [0x13e51db7c]
10 EuphonixSurface::ShutdownConsumer() + 33 (in EuCon) [0x13e51da2b]
10 boost::thread::join() + 91 (in EuCon) [0x13e5d5f0b]
10 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff8431ba6a]
Kernel stack:
10 semaphore_wait_continue + 0 [0xffffff80002815d9]
Thread d90 DispatchQueue 2
User stack:
10 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff842faaa5]
10 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff842fac08]
10 _dispatch_worker_thread2 + 252 (in libSystem.B.dylib) [0x7fff842fb2de]
10 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff842fb7b4]
10 kevent + 10 (in libSystem.B.dylib) [0x7fff842f9c0a]
Kernel stack:
10 kevent + 62 [0xffffff80004786e4]
Thread d8f
User stack:
10 thread_start + 13 (in libSystem.B.dylib) [0x7fff84319e89]
10 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff84319fd6]
10 CanAccessPrecedingBytes(void*, unsigned long) + 698 (in libMotuCoreLibs.dylib) [0x1013f8fba]
10 AllocationUnitTest() + 2122 (in libMotuCoreLibs.dylib) [0x1013f8a7a]
10 usleep + 57 (in libSystem.B.dylib) [0x7fff8431b863]
Kernel stack:
9 semaphore_wait_continue + 0 [0xffffff80002815d9]
1 hndl_unix_scall64 + 20 [0xffffff80002e4874]
1 unix_syscall64 + 544 [0xffffff80004e8168]
1 __semwait_signal_nocancel + 179 [0xffffff8000487442]
1 semaphore_timedwait_trap_internal + 138 [0xffffff8000281c9e]
1 semaphore_destroy + 799 [0xffffff8000281995]
1 thread_block_reason + 264 [0xffffff8000209ab2]
1 thread_go + 2145 [0xffffff8000208fec]
1 thread_setrun + 1344 [0xffffff80002083a4]
1 machine_idle + 210 [0xffffff800022e461]
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
