On a slightly related topic : ) I've been running BFD2 in standalone mode, routing MIDI date through the IAC bus and it's really kind of nice having my drums in a separate app that doesn't crash DP, and even stays alive when DP crashes... Kinda like a 32 bit play? <grin>
Frodo wrote:ON TOPIC UPDATE (imagine that!)
PLAY ENGINE 1.0.045 BETA (64-BIT THREADING) HAS BEEN POSTED:
http://www.soundsonline-forums.com/show ... hp?t=11591
For those who've missed the previous 64-bit Public BETA announcements and releases, these versions indeed access all of the RAM you have installed on your computer even with DP running in 32-bit.
So, the notion that everything on your computer has to be running in 64-bit mode before it will work is not completely true. Apple has said that one can run 64-bit and 32-bit apps concurrently. There may be greater *benefits* with everything running in 64-bit, but the notion that running a 64-bit plugin in a 32-bit app being impossible has been misleading and not 100% accurate.
Doug Rogers has made a point of letting people know that one must use a 64-bit-capable machine. The other situation under which one might experience no appreciable performance benefits is when there are less than 4GB RAM installed in the machine since the whole point was to break this limit.
If your machine can take 8/16/32 GB RAM, all of the memory will now be put to good use.
