Also, I did renumber the leading zeros in at the beginning of instruments (the BPM number). Further though, I found instances where in the name of the instrument itself (in this case in the World Groove loops) I'd find names sort of like this (they're not exact, just an example):
120_djembe_8.sti
120_djembe_9.sti
120_djembe_10.sti
Sample Tank would sort these three instruments in its browser thusly:
120_djembe_10.sti
120_djembe_8.sti
120_djembe_9.sti
Because of this I went through and renamed the files to add leading zeros to "8" and "9". To do that I used a cool utility I found called Renamer. You get a 15-day trial period and after that it's $25, which is somewhat steep but I couldn't find anything else as flexible.
I used Renamer's search and replace function and searched for "djembe_" and replaced with "djembe_0" to fix that issue.
Any way, thought I'd pass along. I really eagerly await your adding drag and drop functionality to Sample Tank for working with loops. It would really be the icing on the cake!
