Page 72 of 80
Techivation T-Saturator - FREE
Posted: Tue May 07, 2024 11:27 am
by James Steele
https://techivation.com/t-saturator/
T-Saturator is a smart level-independent saturation plug-in that gives you precise control over your track’s tone and character. Whether you’re looking for subtle warmth, enhanced dynamic range, or screaming distortion, T-Saturator will get you there with ease.
NESS Spatialization
Posted: Mon May 13, 2024 11:15 am
by cuttime
I have no experience with this, but perhaps someone does. It looks similar to some plugs by Dear Reality, but those are really expensive.
https://ness-apg.com/
EDIT: apparently requires Java to run certain functions.
LOTUS SOUND AUDIO Ocean Plate Reverb - FREE
Posted: Mon May 27, 2024 2:11 am
by James Steele
https://www.patreon.com/posts/ocean-plate-100710016
The YouTube video doesn't really have any audio examples. You can download it and try it out. Also keep in mind that developer doesn't seem to have a proper installer so you have to drag the .component file into your Components folder. This will result in the plug being "quarantined" and it wont pass validation. So prior to launch DP you will have to fix this issue using Terminal as described in this post.
OCEAN PLATE : Analog warmth, limitless creativity !
May 17
Introducing OCEAN PLATE 🌊 – the epitome of warmth, depth, and sonic excellence in the realm of digital audio processing. Crafted meticulously from a stunning analog device renowned for its unparalleled sonic character, Ocean Plate reverb plugin takes your audio to breathtaking depths, enveloping it in lush, immersive ambiance reminiscent of vast, shimmering oceans !
With its rich, warm sound, Ocean Plate is not just a tool ; it's an experience. Whether you're producing music, mixing tracks or designing soundscapes, this plugin infuses your creations with an unmistakable analog charm that sets them apart.
But Ocean Plate isn't just about reverb ; it's a complete sonic sculptor. Featuring a meticulously designed EQ section, you have total control over shaping your sound to perfection. Whether you're dialing in subtle enhancements or completely transforming the character of your audio, Ocean Plate empowers you to achieve your sonic vision effortlessly.
Ocean Plate brings the unmatched quality of analog reverbs within reach of every producer, musician, and sound designer.
Free Mastering the Mix Limiter plugin - need Instagram Account
Posted: Thu Jun 06, 2024 5:33 pm
by James Steele
Just go to this post: https://www.instagram.com/reel/C7zr0d1y21Q/
Leave a comment that just says "Limiter" and you'll get a DM with download and license info apparently.
Mastering the Mix EXPOSE2 - FREE at Plugin Boutique
Posted: Sun Jun 09, 2024 12:11 am
by James Steele
No idea how long this will last. You have to go to Plugin Boutique and get it there and then use the code EXPB100 at checkout.
It's an app that you use to analyze final mixes and detect any issues, and more. Here's the link at Plugin Boutique:
https://www.pluginboutique.com/products/7908-EXPOSE-2
Also more info on the app here:
https://www.masteringthemix.com/products/expose-2
Here's the direct link to the PDF manual for EXPOSE 2 at Plugin Boutique. Might be helpful. Heck, it's free (for now)... grab it and THEN figure out if you can use it.
Free "Inflator" style plugin
Posted: Thu Jun 13, 2024 7:17 pm
by James Steele
Read about this on another forum. Someone commented it wasn't half bad. Might be worth checking out:
https://github.com/Kiriki-liszt/JS_Infl ... tag/v2.0.0
UPDATE: Ignore this... it's a bust. Even after you use Terminal to remove quarantine, AU fails exam and VST3 loads, but doesn't seem to do anything.
QSynthi: a free Quantum Synth
Posted: Mon Jun 17, 2024 2:18 pm
by stubbsonic
The description is pretty fascinating-- (IMHO, more fascinating than the sounds themselves). But still it's an intriguing idea and looks well executed. I didn't download, so I can't vouch for it.
https://qsynthi.com
Ozone 11 Elements for FREE at Sweetwater!
Posted: Wed Jul 03, 2024 10:04 am
by James Steele
https://www.sweetwater.com/software/ozone-elements
Heck... I have the full Ozone 11, but I might try to get a license for this one, because I have Ozone 9 Elements and as I recall the CPU hit on Elements was lighter than the full version.
(Be forewarned... they require your name and address and email to send you the link.)
Techivation T-De-Esser 2 - FREE
Posted: Sun Jul 07, 2024 6:27 pm
by James Steele
Just got this in my email:
Dear Techivation user,
We are thrilled to introduce our latest plugin, the Techivation
T-De-Esser 2— It is FREE!
In July 2021, we released our first audio plugin, the T-De-Esser, which quickly became a favourite among many professionals. To celebrate the third anniversary of the T-De-Esser and Techivation’s entry into the audio software world, we are excited to offer you our brand new T-De-Esser 2 plugin.
T-De-Esser 2 addresses harshness and sibilance issues even more naturally and musically than the T-De-Esser. It enhances the overall mix in a gentle, pleasing manner and can be used on individual tracks, group tracks, or the master buss without causing undesirable effects or artefacts.
The entire DSP algorithm in the T-De-Esser 2 has been upgraded, and it is equipped with additional features. The plugin also boasts the brand-new MK2 user interface from our T series, enhancing workflow and making it more user-friendly.
You can get it here:
https://techivation.com/t-de-esser/
Re: Ozone 11 Elements for FREE at Sweetwater!
Posted: Mon Jul 08, 2024 11:57 am
by mikehalloran
James Steele wrote: Wed Jul 03, 2024 10:04 am Ozone 11 Elements for FREE at Sweetwater!
Ok, free, sure, so I did it.
Well, this was a surprise. Normally, when I install Ozone, Elements and Advanced of any version, whichever I install last works and the other two are unavailable in DP. This has been true ever since the iZotope Product Portal happened again when I allowed NI to install my copy of Ozone 10 (the standard version installs with Ozone Advanced anyway so there's no point).
This has changed with 11. As you can see, the freebie installed alongside the Advanced plugs and there's Standard sitting at the top. Although I do have a copy of Standard in one of my packages, I'm leaving well enough alone.
For kicks, I tried it on Rachmaninov's Rhapsody on a Theme by Paganini with the composer at the piano— 1941 in glorious lo-fi mono. No, it cannot perform miracles but it was fun to see what was possible. It's in 25 parts on my CD, not a problem, but on my iPhone, it's 25 separate pieces so I dumped it into DP awhile back so that it will play back as a single piece in iTunes.
Posted: Mon Jul 08, 2024 8:54 pm
by James Steele
Well, this was a surprise. Normally, when I install Ozone, Elements and Advanced of any version, whichever I install last works and the other two are unavailable in DP. This has been true ever since the iZotope Product Portal happened again when I allowed NI to install my copy of Ozone 10 (the standard version installs with Ozone Advanced anyway so there's no point).[/quote]
Yeah... I'm not sure how, but I was able to have Ozone 9 Elements and the full version installed at the same time at one point. I still have Ozone 9 Elements installed.
Unfortunately (and I think I posted about this in the Plugin "Deals" topic), the CPU savings of the Elements version versus the full version that was there in Version 9 isn't very dramatic in Version 11. Details are in that post here: viewtopic.php?p=613048#p613048
Ozone 11 Elements only saved about 3% on the CPU hit versus the full version of Ozone 11. Oh well...
PressPlay Wave Observer - FREE
Posted: Thu Jul 11, 2024 8:02 pm
by James Steele
https://pressplay-music.com/wave-observer/
Quetzalcoatl: Vector Synth AU/VST3
Posted: Wed Jul 17, 2024 8:57 am
by stubbsonic
Features:
  • An 8 layer vector "oscillator" with harmonic pitch control
    Multimode harmonic filter
    A flexible selection of modulators with LFO, envelope, table, step sequencer and gate sequencer modes
    Diverse sound library sourced from vintage synths
    SFZ, WAV and AIF import
I infer from the various pages that this is still in development, and will have some bugs; and that there is or will be an "expanded" version which appears to have a name-your-price field. There also appears to be a sibling product called Xolotl which you can view by clicking the "Brother Synth" link on the github page.
I love the color scheme and graphical elements of the GUI.
https://github.com/publicsamples/Quetza ... me-ov-file
Waves OneKnob Driver FREE for limited time
Posted: Sat Aug 03, 2024 7:35 pm
by James Steele
https://www.waves.com/account/free-one- ... tering-com
Glitch? Act Fast! T-RackS Studio Bundle... normally $299 - FREE with code
Posted: Mon Aug 05, 2024 12:28 pm
by James Steele
Saw this on another site just minutes ago...
Follow this link:
https://www.pluginboutique.com/products ... AuQksufGAq
At checkout enter this coupon code: naka178u
I tested it and it worked as of 12:25pm PDT. It changed the price to FREE. Just don't bother adding the free gift when you put it in your cart, because it will be removed when you enter the code. I would have jumped on myself, but already have them.
