Do's ans Don't's for a Crash free DP
Most of what I've been reading here I actually do. : ) I use seperate drives for media, apps, etc.. I always bounce to a seperate drive from the one I am working the session on. I use a G4 800 with 1.5 gig ram and three hard drives. The only time I will have issues is when I try using more plugins than my processor can handle. VI's are hogs as well so I tend to stick with outboard MIDI. I'm constantly learning tricks to maximize my track count like burning the effect to the track and then removing it from the loop (compressors, EQ, etc...) Since I've been reading forums here and learning different techneques I haven't had a "crash" in months. I've never cleared history and I stopped deleting unused soundbits because I was saving multi takes as Bla.v1, Bla.v2,etc...
And along the way I was bouncing tracks together and so I found the hard way if I deleted unused soundbites they would not be available for me in the earlier session. (I admit I did receive a warning - I ignored) No crashes lately to report.
dpg4macman
dpg4macman
Re: leave your disk 50% empty
And finally my happy statement was false. The crash on stopping the record process came back. That has no connection to the amount of free disk capacity. Sorry.arion wrote:After having continously crashez, quits on save, etc finally I cleaned my disk containing audio and voila - ALL PROBLEMS ARE GONE.
LEAVE ALWAYS 50 % OF YOUR DISK FREE.
I have been working - sometimes relaxed - without problems for 4 weeks after one year suffering.
( Yes the start was also fine, untill my disk became 90% full. )
I never got a hint tot this direction from the supports of the suspected manufacturers.
g5 Quad ppc, 8G RAM, osx 10.4.11, dp 5.13, mach5, msi, MIO 2882, micro express
If I'm using Play's Voices Of Passion or the Trilogy/Atmos wrapper, then around 10.José Herring wrote:How many crashes in an average workday do you guys experience?
If not then 0.05!
G5 8 Core DP 7.1 OSX Snow Leopard 13GB RAM DP + Bidule
VI's : RA / MX 4 / V-Station / NI Complete/ Mach 5 / Arturia MiniMoog V / EWQLSO Gold / GPO / Stylus / Atmosphere
Also using lots of Giga libraries (VSL / SAM / MV) via GS3 on PC running MidiOverLan and Remote Desktop
- daniel.sneed
Around 0.02 crash a day.
And some very rare COQ with no consequences at all.
dAn Shakin' all over!
DP11.32, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
- Eleventh Hour Sound
Hard Drives are people too
I'm finding that if I listen to my little hard drives clicking away and wait until they stop after something like a recording pass, or edit or something, I rarely have some of the crashes I used to often get when hitting rewind right after recording a new take or throwing a bunch of commands at it before it's done writing all the last batch of 1's and 0's...
I can be pretty demanding on my gear when I'm working fast, but I guess (if this is actually accurate) it could be learning to listen to your machines kind of like you listen to your car. You know when your car is starting to struggle; either revving too high or even pinging, or grinding gears, so you might back off a little and work with it...
My G5 and external drives are right under my desk so it's pretty easy for me to hear them. Another solution I guess could be a utility that graphically shows you drive access.
So I wonder how many of my huge crash and burns could have been saved by this technique and I wonder if this is a feature MOTU could add to DP. (The "Let your hard drives catch up" preference : )
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
- daniel.sneed
I agree with you RecordingArts.
Allowing needed time to DP and the hard drives is a good habit (should I say *hobbit* ?).
If your setup si prone to crash, investigate in this direction is a must.
BTW the small Activity Monitor floating CPU bar (one for each, in case multiple processors) is very usefull to learn what is happening under the hood.
It's always on in my setup.
BTW my Seagate HD is totally silent !
- ramadev
Re: Hard Drives are people too
MenuMeters works well for me; it shows HD access, CPU usage, memory and network status in the menu bar. And it's free.RecordingArts wrote:Another solution I guess could be a utility that graphically shows you drive access.
http://www.macupdate.com/info.php/id/10451
Also here:
http://www.versiontracker.com/dyn/moreinfo/macosx/17713
Nehalem Dual QuadCore 3.2GHz/8GB/828/MTP AV/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/GuitarRig4/Drumagog/bx_XL/FG-X,RC-Tube,VTM/EventideOmnipressor/MelodyneStudio-Cre8 3.2
MacBook Pro Intel Core 2 Duo 2.66GHz/2GB/Traveler/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/bx_XL/MelodyneStudio-Cre8 3.2
Neumann,AKG,Earthworks,Soundelux mics/ManleyVoxBox/Avalon737/Amek9098/Genelec1031As
ramadev wrote:MenuMeters works well for me; it shows HD access, CPU usage, memory and network status in the menu bar. And it's free.RecordingArts wrote:Another solution I guess could be a utility that graphically shows you drive access.
Also here:
Thank you, ramadev!ramadev wrote:MenuMeters works well for me; it shows HD access, CPU usage, memory and network status in the menu bar. And it's free.RecordingArts wrote:Another solution I guess could be a utility that graphically shows you drive access.
Also here:
Whilst not official, folks reckon it runs fine under Leopard.
I noticed you don't appear to be running Leo yet.
Would you risk it? (my system suffers from quite a few unexplained issues).
- ramadev
You're quite welcome Mr. Monkey, I hope it works poo-fectly for you. And you're welcome too RecordingArts. Always glad to be of service; I've learned so much here, so I'm grateful for an opportunity to contribute.monkey man wrote:Thank you, ramadev!
I sure will, as soon as I finish a couple of reeeeaallyy old projects that one client just can't let go of. I'm reluctant to upgrade the OS in the middle of these very large projects; we're actually still in DP 4.61 for these, and we started them in DP 3.0!! (Yes I did upgrade to OSX and DP 4.12 & 4.61 during these sessions after meticulously backing up and crossing my fingers.)monkey man wrote:I noticed you don't appear to be running Leo yet.
But my system is also having a few issues, notably the ol' "error message = -199" one. Seems some files won't open on my system, but they do open on others. I've tried removing audio files, trashing analysis & fade files, removing plugs, and loading into a new project - nothing has worked. Doesn't matter if I try DP 4.61 or DP 5.13. I may have to wipe the drive and start over. Maybe I'll just save up for a Mac Pro; that would probably be easier in the long run since the G5 is usually running at 70-80% CPU usage on both processors, according to MenuMeters.
LOL! Thank you mate.ramadev wrote:You're quite welcome Mr. Monkey, I hope it works poo-fectly for you.monkey man wrote:Thank you, ramadev!
I must be an easy room, 'cause I'm still laughing at your poo joke.
Sounds reasonable - take the king hit and get it out of the way... after you've finished that project, eh?ramadev wrote:I sure will, as soon as I finish a couple of reeeeaallyy old projects that one client just can't let go of. I'm reluctant to upgrade the OS in the middle of these very large projects; we're actually still in DP 4.61 for these, and we started them in DP 3.0!! (Yes I did upgrade to OSX and DP 4.12 & 4.61 during these sessions after meticulously backing up and crossing my fingers.)monkey man wrote:I noticed you don't appear to be running Leo yet.
Good luck man.
FWIMBW, I dread the day I won't be able to load an old project, in fact I expect it seeing as I've around 200 unfinished songs.
Update:
MenuMeters, whether I use the installer or drag the extracted Pref Pane to the relevant folder, always disables MainMenu, a utility I run in the background and that I use for my shut-down routine.
No amount of app launching (MainMenu) remedies the situation.
The MainMenu bar icon disappears the instant one clicks the "display" checkbox under any of the various MenuMeters tabs.
Just a heads-up to watch out for that one; I'm not convinced MenuMeters is Leo-compatible yet, even though folks have said it runs fine for them.
