Awesome. Thanks for posting this. But does anyone know of a link to a more full length video? This one is highly abridged and skips over some the most intriguing new features, like the new Track Folders features.
Thanks,
Babz
I just tried to open the same files that Charles tried and they both open in under 30 seconds and the saves were in the 2-5 second range.martian wrote:hi charles thanks for that..charlesparente wrote:
Hi:
I was able to open both the 'r1 v127 int logo' DP file
and the 'r3 v107 copy' DP file in under 30 seconds using DP 7.02.
I didn't try the other files.
Charles
it's interesting/ good to hear. i dont mind being wrong ( good job really )
and are the saves equally fast?
why do you think my brand new mac book pro on 10.6.1 is so slow opening? ( i think I got 4gig RAM in there )
it's also crawling on my mac pro dual 3ghz -
everythin else is fine - great infact! just slow saves and loads.. seeing as I havent crashed in about a week it's not massive - and I can sllip it into my work flow (unless director in room then gets a bit nervy )
yes thanks - those new automation trims look handy too!
I'm generally working with a lot of audio files although your project does have more short clips than what I generally deal with.martian wrote:hey thanks for confirming that K!
so i just put 7.02 on my wifes macbook - and downloaded the same files as you guys..
and guess what?!!! they open in under 30s...
is it because of no audio files being present I wonder?
Are you guys generally working with just VI's? and synths n stuff - as opposed to lots n lots of audio files?
Do us a favor and also try copying the project and merging/deleting all the soundbites and then test open/save. Just to see if there is any merit to the theory that this is causing your delay. I'd be interested to know especially now that I am familiar with your sessionmartian wrote:I just copied the audio files back to the macbook - and once again the loads returned to the several minutes...
i guess it's one of those limitations of DP that I can live with. i cant merge stuff really until the very last moment - generally I am still premixing dialog til last minute - fine tuning foley etc - so merging would loose muted alt takes for instance and also s/bite names,, I can see what you mean about merging - but I am trading off long loads and saves for client driven flexibility right up to last unfortunate second..
I may experiment again -
this project is in AIFF - I may try wav files and compare!
I must admit - I dont pick up my guitar much these days - but those new amp models are a wet dream! can the latency come close to a hardware? - something else to try when less busy!
I can't say for sure, and I certainly haven't pushed DP very hard since upgrading to 7 (no heavy editing with lots of fades). But I was concerned about CPU hit - I'm on an old G5 - and haven't noticed any problems.martian wrote:is there any trade off with the realtime fades? it seems there must be more maths involved? so that suggests CPU hit?
Thus far it works as advertised and it is awesome.mhschmieder wrote: If auto-save works as advertised, all of our lives will be made easier, since sometimes it is not possible to do a save due to a process that has grabbed focus, or we might forget due to frustration at slow load times etc.
