traveler question
tricky
traveler question
Post by tricky »
hi there can i use the mic preamp inputs on the traveler for line level instruments synths etc and what would happen if i switched the phantom power on while say a synth was connected. cheers
alobonzo
Post by alobonzo »
Well u can use as line inputs.
I'm not sure what happens when u power the phantom while a synth is connected, maybe u break your audio monitors...
hehe
PB G4+Presonus Firestudio+DP
iMac Core2Duo + Cubase4+Toneport UX2
Apple Certified Trainer - Final Cut Pro 6
rockitcity
Re: traveler question
Post by rockitcity »
tricky wrote:hi there can i use the mic preamp inputs on the traveler for line level instruments synths etc and what would happen if i switched the phantom power on while say a synth was connected. cheers
I haven't seen the wiring diagram of the combo 1/4"-XLR connector on the Traveler, but I assume that phantom power would only be applied to the XLR pins 2 & 3. So, probably nothing would happen if you turn on phantom power with a synth plugged into the 1/4" input. Still, I'd avoid it if possible. Sounds like you may have already done it and wonder if you blew anything up?
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
