Can't Export? (please help gotta hand over files in 30 min)
kid-surf
Post by kid-surf »
Hey dudes...
The error I'm getting is:
"Mas, 1 error reported by Core Audio Export Plugn/Core Audio Support code.
CAAudioFile.cpp 209-37 create audio file[-37]"
I have no clue what that means but I'm simply trying to export audio files. Any guesses? Any work arounds?
I'm on a G5 2.5 10.4.3 , DP4.6
Thanks....
Eleventh Hour Sound
Re: Can't Export? (please help gotta hand over files in 30 m
Post by Eleventh Hour Sound »
Hmmm Don't know if this will help you in time, but when I want to do a quick and dirty mix I use Audio HiJack. It may take you a few minutes to install and figure out, but basically once it's set up you can use it as a 2 track mastering deck. You can use "record" in almost any format, send it to iTunes, burn to cd and you're done.... :D
http://www.rogueamoeba.com/audiohijackpro/
kid-surf wrote:Hey dudes...
Thanks....
:D
kid-surf
Post by kid-surf »
I'll try that if worse comes to worse.... thanks!
I'm dragging the file to another computer to see if that works? this is a pain..... arrrr!
Eleventh Hour Sound
Actually looking at this I just realized what you were saying. I don't think you can use the core audio export. I recommend using AIFF or SD II. Either one should work and burn to CD...
Thanks....
kid-surf
Post by kid-surf »
Hmmm, it seems to work if I do it one file at a time... I wonder why?
Oh well, at least I got the files out.
Something is whacky here, though...... it's worked every other time. And when I opened it up on my other computer it did the same thing. Maybe I'm just over-tired and doing something stupid...?
Thanks for the help....
