I have a Quicksilver dual 800 mac, OS 10.4.5. My stock Superdrive can burn DVD's at a speed of 2X, maximum. I intend to pick up an external Firewire DVD burner (the LaCie with Lightscribe) soon. Will burning my DP data backups at 8X or 16X cause a greater disk read error problem? Or should I play it safe and burn them all at 1X as suggested by some?
Thanks in advance for your help,
Bill
Best burn speed for DVD backups?
I rarely use the drive's fastest speed simply because of performance headroom. I most often run at 8x on my 24x drive until the data is ultra critical, then 1x does the trick. I have had a few instances of errors at 8x but not many, and I've never burned at rates higher than that.
When in doubt, 1x.
When in doubt, 1x.
6,1 MacPro, 96GB RAM, macOS Monterey 12.7, macOS 10.14, DP9.52
