CPU overloads while recording
Hello Folks,
I've had problems recording with DP5.01. I'm using a G4 pwbk 1.5mhz w/1gig ram. I'm getting CPU spikes that corrupt recorded tracks. It does not happen consistantly. Plus with the activity monitor showing that DP is only using on average of 50% user power. Plus I have every non essential option turned off. This happens with only 2 tracks! I've repaired permissions, ect and it presists. I'm using it for concert recording and have to change software if I can't fix this. Please, any advice would help.
Don
Don
Some questions:Don S wrote:Yes I did - but thanks for the info. A very simple project with 4 tracks, 2 in record the other 2 empty, running at FS1 (44.1) No plugs - nothing else. And I'll get the Audio has overloaded your CPU, and the stream being recorded gets corrupted. Not stable or professional.
Are you recording to the same drive that DP is installed on?
Have you tried adjusting buffer settings?
Have you tried adjusting work priority settings?
Are you recording using Firewire? Are there other devices addressing your Firwire buss?
These are some of the common culprits regarding the "CPU overload warning" window.
- kelldammit
- Primary DAW OS: Windows
something's up, and i don't think it's dp itself...it's got to be a settting somewhere. i have a roughly equivalent system, and i can record 16+ channels of 48k/24bit vi outputs to audio in one pass without any such problem. i don't even remember what my cpu usage was, but it was not high.
1.67ghz g4 pb, 1g ram, internal drive, or external, makes no diff.
- Timeline
Run DiskWarrior
You might be right! I'm trying to remember when these problems started. Either when I upgraded to 10.4.5, or when I switched work priority to high.kelldammit wrote:something's up, and i don't think it's dp itself...it's got to be a settting somewhere. i have a roughly equivalent system, and i can record 16+ channels of 48k/24bit vi outputs to audio in one pass without any such problem. i don't even remember what my cpu usage was, but it was not high.
But I've been usung DP since 4.5 and did not always have this problem. I record concerts, so the files are long. Usually about an hour.
- Pappy725
Work priority should be set to medium. I was getting some spikes also and raised my buffer to 1024 and everything is fine now.
Stephen
Stephen
- mikebeckmotu
second the problem
I am running into the same problem, which I also did not experience using DP 4.6 -- also running a PowerBook G4, but using very few tracks and no plug-ins -- tracks recorded to separate HD -- Could this be a bug of some kind?
hmmm. Are you using the built in audio ins and outs, or an external interface?
I remember having some issues with my old G4 1.5 Powerbook, but they wouldn't happen if the buffer wasn't too low, and if the system load was low.
Digital Performer 5.12
Macbook Pro 2.4 ghz 4GB RAM 160GB HD
Power Mac G5 Dual 2.0 ghz 2GB RAM 320GB HD
Motu 828 mkII
Motu 828 mkII
