This might sound like a silly question... Talking hardware taking a signal from a Mic:
Is it Amp ==> Compressor
or
Compressor ==> Amp
Amp => Compressor
signal chain should be...
Mic --> Compressor/effects --> Amp --> Speakers
60% Of the time...it works EVERYTIME!!
http://www.zara-music.com
http://www.soundclick.com/zara
http://www.soundclick.com/mattradlauer
ahh...details details!!
- mhschmieder
If you're miking the speaker cabinet, you're already getting some compression (or at least peak limiting) and probably will not need additional compression for that channel. I only use it on direct signals, and then only at mix-down time.
But if you are talking in terms of compression as a special effect, then it also depends on impedance matching and not just artistic decisions or logical flow, as not every compressor (whether a rack unit, stomp box, or plug-in) consistently assumes serial or parallel processing.
