Vacuuming lowers processor load??
I was working on a DP5 project and MenuMeters was showing a load on my dual 2.5 G5 as 95% and 91% for a good portion of the piece.
Fortunately I had saved everything because the computer suddenly went to sleep and wouldn't wake up (locked up). It had done this a few times recently on heavy DP projects and Animation Master renders.
The temperature in the room has been about 80 degrees F in these instances. Fortunately I still have Apple Care.
But then I decided to check inside the computer and the processor grill was completely coated in dust! I scraped off a good portion that looked like it came from my dryer's lint trap, and then decided to vacuum the grill for good measure.
Now the same passage of the project which read 95% and 91% processor usage on numerous plays now reads 86% and 79%.
I would understand if the temperature meters went down, but the processor meters? Perhaps the auto processor function slows them down when they get overheated and my dust-clogged maximum was quite a bit less than dual 2.5 GHz?
The same Animation Master renders don't make the computer lock up either!
Has anybody else had an experience like this?
Jim
Jim
- BradLyons
- Primary DAW OS: Windows
It has to do with airflow, if the computer can breathe it can run at optimal performance it was designed to. But if it can't get that air-flow, it starts to struggle and tries harder to breathe. Imagine if you're swimming and start dipping under water, you're going to start working harder to breathe.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
Yeah, I understand that. But I have "Processor Performance" set to "Highest." I would have thought if it was overheating, it would have reached 95% and then died, but the same project would now go to 95% and not die. Or what now works great at 85% would have died at 85% when clogged with dust; I didn't know MenuMeters' meters were scalable, as if the processor was throttled back even though I had it set to "Highest."BradLyons wrote:It has to do with airflow...
I guess if anybody has performance issues, make sure the CPU is clean.
Jim
- Timeline
It's logocal. Have to give that a try.
- mhschmieder
- Timeline
Added: Found can of Air Duster compressed air can do wonders with a vacuum when you blast air towards the vacuum nozzle. You need to get the dust off the heat syncs for sure to keep them form throttling the CPU.
- toodamnhip
computers breathing?BradLyons wrote:It has to do with airflow, if the computer can breathe it can run at optimal performance it was designed to. But if it can't get that air-flow, it starts to struggle and tries harder to breathe. Imagine if you're swimming and start dipping under water, you're going to start working harder to breathe.
OMG..
can anyone say "I Robot"?......
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- philbrown
Watch out vacuuming electronics - I always thought that was a no-no because of the buildup of static voltage can pop yer chips. I know I've been shocked by a shopvac more than once. I always take stuff outside and blow with a can of air or air compressor instead. You know, blow instead of suck.
And turn your head really far away -it's amazing what accumulates all up in there.
Shop-Vac?!philbrown wrote:I've been shocked by a shopvac more than once.
Please note: I am not responsible for any damage to your computer caused by vacuuming it!
It worked for me, but I have a little suck/blow electronics vacuum.
I often touch the components in my computers as well (good touch, not bad touch), but I wouldn't do that after sliding my stocking feet all over the carpet!
I've never had to clean a computer's heat sync before, but I guess I've never had a computer that was so prone to overheating as the 2.5 G5.
Jim
Running at temp close to the semi conductors your best option is to reduce the delta T by a degree or two. The alfa (heat conductivity between gas and solid) will be close to constant at high pressure drops / air speed.
So in this case move the computer to a slightly cooler place in the room. 2-4F lower will quite likely do the trick.
Dual 2.0 G5/3.5GB, 10.4.6, DP 5.0, 828mkii
