828mkii will not complete power on/boot cycle...
AgincourtDB
Post by AgincourtDB »
"MOTU 828mkII" appears, then a second later, "CueMix DSP" appears.
Then, the "MOT" of MOTU dissapears, and it's frozen. the firmware number does not appear.
it does this with and without the firewire cable attatched. Sample rate does not light up.
HELP, I have a live recording tomorrow night.
-Dave B (aggie)
Smokehouse
Post by Smokehouse »
You might be in trouble. For a long shot, try (with power not connected) moving the red 110/220 switch back and forth (and then back to the right position!!). THere's also a way to do a total factory reset. I forget how, but a search on "828 factory reset" or the on this board or MOTU's support database should get you there. Also, get on the phone with MOTU in the morning. BE THE FIRST CALLER. Things in the AM are much less busy than later in the day.
"I'll try anything twice."
Dell Latitude E6400 w/ WIN XP SP3, ADS Pyro 1394 FireWire
SONAR 8.5, WaveArts TrackPlus & MasterVerb, AutoTune 4.1
MOTU 828 MKIII, MOTU 828mkII, Presonus Digimax LT
AgincourtDB
Smokehouse wrote:You might be in trouble. For a long shot, try (with power not connected) moving the red 110/220 switch back and forth (and then back to the right position!!). THere's also a way to do a total factory reset. I forget how, but a search on "828 factory reset" or the on this board or MOTU's support database should get you there. Also, get on the phone with MOTU in the morning. BE THE FIRST CALLER. Things in the AM are much less busy than later in the day.
Unfortunately in order to do the factory reset the 828 has to boot in the first place. It looks like I'm calling. :x
-Dave B (aggie)
