Registration window key code DP 5
I am trying to open DP 5 for the first time and I get the registration window. When I introduce my name and key code the program does not open. I get the same window again. I have tried like 100 times. It is like is not accepting the key code is in the user's manual. Wrong key code? Problems with the installation disc?
Mac OSX 10.3.9
G5 Dual 2 GHz POwer PC
Mac OSX 10.3.9
leave the...... oh call motu they'll help
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
Re: Registration window key code DP 5
If you have the DP5 install disk, and keycode isn't working, then you need to call MOTU.wcroes wrote:I am trying to open DP 5 for the first time and I get the registration window. When I introduce my name and key code the program does not open. I get the same window again. I have tried like 100 times. It is like is not accepting the key code is in the user's manual. Wrong key code? Problems with the installation disc?
Mac OSX 10.3.9
have you connected the dongle correctly?
I can understand that you're in doubt about a person with just 1 post, but this can be a legitimate new owner.homebilly wrote:have you connected the dongle correctly?
It once happened to me (yes, with the original disk inserted, the name with at least 3 characters, and the correct code) and no matter what, the registration window kept coming back.
Repaired permissions with Disk Utility and the registration process completed sucessfully.
- Shooshie
caps lock?
The original post asks if it's possible he has a bad installation disk. And there are four possibilities I can see:96khz wrote:I can understand that you're in doubt about a person with just 1 post, but this can be a legitimate new owner.homebilly wrote:have you connected the dongle correctly?
1. Not placing the install disk in the machine when entering the key code.
2. Mixing up the number 0 and the letter O.
3. The installation was bad or permissions need to be repaired.
4. The install disk itself is a problem and needs a replacement.
he didn't mention that he had the disk in the drive or that he knew that it was needed for that matter but i guess you just told him what the manual clearly states ASSUMIMG THAT HE HAD A MANUAL!
i was about to tell him when i realized that he hadn't mentioned the CD so i figured he could either call MOTU or re-post and phish some more.?
Thank you guys.
The problem fixed with the Disk Utility Repair Permissions.
