"No MOTU PCI cards detected" error
Hello.
I just unboxed and installed the PCI-424 card that came with my 24 i/o, installed it in my Mac (Dual 2Ghz G5, OSX 10.4.6) in PCI slot 2, and when I booted and try to run MOTU PCI Audio Console (or CueMix Console) it says "No MOTU PCI cards detected". When I try to run Audio Desk, it says "No audio hardware was found. (MotuAudioSystem Mas MasCorAudioDeviceSet.cpp, 111 [58:0]).
My 24 I/O, which is attached (in the socket closest to the ADAT sync port), is blinking 44.1 clock light and doing nothing else.
I have checked with this technote:
http://www.motu.com/techsupport/technot ... patibility
And I do have the PCI-X model with the 3 tabs ratherthan the two tabs, and my Mac Dual G5 model A1047 has PCI-X slots.
Any advice would be greatly appreciated, as I'm not getting MOTU to respond to support mails, and I'm not finding other relevant troubleshooting advice online or in the printed docs (but if I'm just overlooking it, please point me at it).
Thank you!
- S
Thank you!
- S
I had a similar problem and read somewhere on this forum that you should use the PCI slot furthest away from your video card, so I moved my PCI 424 card from slot 2 to slot 5 and it worked!
Leon Portelance
Songbird Productions - Kaatza Music
PCI 424, MOTU 2048mk3 & MOTU MIDI Express XT
in a Mac G4 dual 800, OS 10.3.9, 1.5 Gig RAM, 2 x 120 Maxtor HDs, Logic 6.4.3
Hi. Thanks.
So, I got this working. I wound up moving it to slot 3 (which isn't furthest from my video card... maybe I'll move it farther just to prevent RF interference if there is such a possibility). I also installed a newer version of the drivers from the MOTU website. Now, on to testing actual audio I/O from the 24io.
Thanks for the responses.
- S
- S
sbugaj,
That furthest slot thing may actually be specific to a certain line of Mac motherboard's slot resources, rather than to avoid "induced" noise from the graphics card (I'm not sure on that). I know on a bunch of PC boards, the slot right beside the graphics slot shares resources with the video card, so it's usually not recommended. The other slots are also linked to different things, and it's different for different boards. FWIW, I think my 424 *has* problems in the last (bottom) slot on my ASUS PC board. I'm pretty sure I've got it in the 4th or 5th one (right before the last).
Either way, if your tests come out good, that's all that really matters.
George
George
Well, my card was seen and all that. And in Audio Desk I can prep a track for recording, monitor that channel with Studio -> Audio Monitor and see signal, but when I try to record Audio Desk just quits without an error message into the OSX "Problem Report" mode in which it reports the Exception: EXC_BAD_ACCESS and a pile of other info. I've forwarded this on to MOTU tech support, but my last question took them 2 weeks to answer so I've been poking around forums and manuals to try to figure out what's up but so far no luck.
Here is the very long dump from the crash (If anyone's seen this before and knows what to do about it, I'd love to hear from you. Thanks.):
Date/Time: 2006-05-10 11:28:09.117 -0700
OS Version: 10.4.6 (Build 8I127)
Report Version: 4
Command: AudioDesk
Path: /Applications/AudioDesk 2.03.app/Contents/MacOS/AudioDesk
Parent: WindowServer [60]
Version: 2.03 (2.03)
PID: 203
Thread: 9
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000014
Thread 0:
0 libSystem.B.dylib 0x9002c218 semaphore_wait_trap + 8
1 PerfFoundation.dylib 0xefd534fc PerfWorkerThread::DoAction(PerfWorkerThread::Action*) + 120
2 PerfEngine.dylib 0xef8316c4 RunPollThreadTask(PollThreadTask*) + 196
3 PerfEngine.dylib 0xef7942b4 GlobalTimebase::GetTick() const + 92
4 com.motu.AudioDesk 0x000b3c74 0x1000 + 732276
5 com.motu.AudioDesk 0x000b3ba0 0x1000 + 732064
6 com.motu.AudioDesk 0x000b3814 0x1000 + 731156
7 com.motu.AudioDesk 0x000b3460 0x1000 + 730208
8 com.motu.AudioDesk 0x00007014 0x1000 + 24596
9 com.motu.AudioDesk 0x0058eff8 0x1000 + 5824504
10 PerfEngine.dylib 0xef805234 DisplayPollGuts(bool) + 168
11 PerfEngine.dylib 0xef805638 TimerDisplayPoll(double) + 20
12 com.motu.AudioDesk 0x00639270 dyld_stub__ZN9UniCursorC1Es + 1604
13 com.motu.AudioDesk 0x0050d7ac 0x1000 + 5293996
14 com.motu.AudioDesk 0x0050d0b4 0x1000 + 5292212
15 com.apple.CoreFoundation 0x907f7aec __CFRunLoopDoTimer + 184
16 com.apple.CoreFoundation 0x907e4464 __CFRunLoopRun + 1680
17 com.apple.CoreFoundation 0x907e3a18 CFRunLoopRunSpecific + 268
18 com.apple.HIToolbox 0x9321d980 RunCurrentEventLoopInMode + 264
19 PerfFoundation.dylib 0xefd4bc88 Yield(double) + 72
20 GenericPanes.dylib 0xef57375c GenericButtonTrackingLoop(short, bool, Rect*, void (*)(void*, TransitionTo), void*) + 108
21 GenericPanes.dylib 0xef571510 GIconButton::HandleClick(EventRecord*) + 200
22 PerfFoundation.dylib 0xefd2e250 GlogPane::GlogMessage(short, long) + 564
23 GenericPanes.dylib 0xef5710e8 GIconPane::GlogMessage(short, long) + 240
24 GenericPanes.dylib 0xef571660 GIconButton::GlogMessage(short, long) + 164
25 PerfFoundation.dylib 0xefd29224 GlogArgDispatch(glogRec*, short, short, void*) + 140
26 PerfFoundation.dylib 0xefd2706c HandleGlogEvent(glogRec*, EventRecord*, short*, long*) + 1052
27 com.motu.AudioDesk 0x000af15c 0x1000 + 713052
28 PerfFoundation.dylib 0xefd30400 DoGlog(EventRecord*, glogRec*) + 144
29 com.motu.AudioDesk 0x000055b0 0x1000 + 17840
30 com.motu.AudioDesk 0x000056f4 0x1000 + 18164
31 com.motu.AudioDesk 0x00005208 0x1000 + 16904
32 com.motu.AudioDesk 0x00004b08 0x1000 + 15112
33 com.motu.AudioDesk 0x00004938 0x1000 + 14648
Thread 1:
1 AllUtilitiesLib.dylib 0xefee337c PerfCoreMutex::lock() const + 52
2 AllUtilitiesLib.dylib 0xefee3188 PerfRecursiveMutex::lock() const + 60
3 PerfEngine.dylib 0xef82e948 PerfTimer::Off() + 24
4 PerfEngine.dylib 0xef7f94d0 do_TimerOff() + 64
5 PerfEngine.dylib 0xef8e9bb4 GlobalTimebase::doGetTickTask::Run() + 32
6 PerfEngine.dylib 0xef91c3f0 PollThreadMethod::doAction() + 40
7 PerfFoundation.dylib 0xefd538c0 PerfWorkerThread::Run() + 196
8 PerfFoundation.dylib 0xefd537e8 PerfWorkerThread::ThreadFunc(void*) + 20
9 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x9000b0a8 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000affc mach_msg + 60
2 com.apple.audio.MIDI.CoreMIDI 0x96715ac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.MIDI.CoreMIDI 0x96708c80 MIDIInPortThread::Run() + 64
4 com.apple.audio.MIDI.CoreMIDI 0x9670cf44 XThread::RunHelper(void*) + 28
5 com.apple.audio.MIDI.CoreMIDI 0x9671687c CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 3:
2 com.apple.CoreFoundation 0x907e4114 __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907e3a18 CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x9148c83c HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x9148c5dc CAPThread::Entry(CAPThread*) + 96
Thread 4:
2 MotuAudioSystem 0xefe5b928 MasWorkerThread::Run() + 108
3 MotuAudioSystem 0xefe5b8a4 MasWorkerThread::ThreadFunc(void*) + 44
4 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 5:
1 MotuAudioSystem 0xefe55cd0 MasSemaphore::wait() + 20
2 MotuAudioSystem 0xefe4ea0c MasCoreAudioWorkThread::HandleWakeup() + 528
3 MotuAudioSystem 0xefe50234 MasPeriodicThread::start(void*) + 356
Thread 6:
2 MotuAudioSystem 0xefe76234 MasJobQueue<MasJob>::Run() + 468
3 MotuAudioSystem 0xefe7604c MasJobQueue<MasJob>::start(void*) + 16
Thread 7:
Thread 8:
0 libSystem.B.dylib 0x90054fc8 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90071648 pthread_cond_timedwait_relative_np + 556
2 com.apple.audio.CoreAudio 0x9149d970 CAGuard::WaitFor(unsigned long long) + 204
3 com.apple.audio.CoreAudio 0x9149d880 CAGuard::WaitUntil(unsigned long long) + 304
4 com.apple.audio.CoreAudio 0x9149bac4 HP_IOThread::WorkLoop() + 852
5 com.apple.audio.CoreAudio 0x9149b75c HP_IOThread::ThreadEntry(HP_IOThread*) + 16
6 com.apple.audio.CoreAudio 0x9148c5dc CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 9 Crashed:
0 PerfEngine.dylib 0xef8638bc FunQueue<Tick>::PopIfDue(Tick, void (*&)(Tick, long), Tick&, long&) + 132
1 PerfEngine.dylib 0xef863588 FunQueue<Tick>::SendInternal(Tick) + 100
2 PerfEngine.dylib 0xef7b07a8 WakeupManager::DoHeartbeatWakeupGuts() + 1320
3 PerfEngine.dylib 0xef7affa8 WakeupManager::DoHeartbeatWakeup() + 60
4 PerfEngine.dylib 0xef82eba0 PerfTimer::ThreadFunction(void*) + 192
5 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 10:
0 libSystem.B.dylib 0x9002edcc kevent + 12
1 com.apple.DesktopServices 0x9288a2b0 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
2 ...ple.CoreServices.CarbonCore 0x90bc9260 PrivateMPEntryPoint + 76
3 libSystem.B.dylib 0x9002ba68 _pthread_body + 96
Thread 11:
0 libSystem.B.dylib 0x9002c128 semaphore_wait_signal_trap + 8
1 libSystem.B.dylib 0x90030bec pthread_cond_wait + 480
2 ...ple.CoreServices.CarbonCore 0x90bc9450 MPWaitOnQueue + 224
3 com.apple.DesktopServices 0x9288a92c TNodeSyncTask::SyncTaskProc(void*) + 116
4 ...ple.CoreServices.CarbonCore 0x90bc9260 PrivateMPEntryPoint + 76
Thread 9 crashed with PPC Thread State 64:
srr0: 0x00000000ef8638bc srr1: 0x100000000000f030 vrsave: 0x0000000000000000
cr: 0x22000012 xer: 0x0000000020000000 lr: 0x00000000ef863588 ctr: 0x00000000005901e0
r0: 0x00000000ef986a0c r1: 0x00000000f0509b50 r2: 0x0000000000000000 r3: 0x00000000ef986a00
r4: 0x0000000000000001 r5: 0x00000000d70a3d71 r6: 0x00000000f0509bf0 r7: 0x00000000f0509bf8
r8: 0x00000000f0509bf4 r9: 0x000000000214460e r10: 0x0000000000000000 r11: 0x00000000ef9839e4
r12: 0x00000000005901e0 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x00000000ef986998 r18: 0x00000000ef9869f8 r19: 0x0000000000000000
r20: 0x0000000012399c4b r21: 0x0000000000ca5a10 r22: 0x0000000000ca5ba8 r23: 0x0000000000ca5bdc
r24: 0x0000000000000000 r25: 0x0000000000000000 r26: 0x00000000efd82500 r27: 0x00000000f0509bf0
r28: 0x00000000f0509bf8 r29: 0x00000000f0509bf4 r30: 0x00000000ef9869f8 r31: 0x00000000ef986a28
Binary Images Description:
0x1000 - 0x83bfff com.motu.AudioDesk 2.03 /Applications/AudioDesk 2.03.app/Contents/MacOS/AudioDesk
0xc90000 - 0xc92fff com.apple.textencoding.unicode 2.0 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1fa4000 - 0x1fa5fff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x1630a000 - 0x16343fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x16399000 - 0x163bdfff com.motu.driver.PCIAudio.HALPlugIn ??? (1.0.6) /System/Library/Extensions/MOTUPCIAudio.kext/Contents/PlugIns/HALPlugin.bundle/Contents/MacOS/HALPlugin
0x163dc000 - 0x16419fff com.apple.QuickTimeFireWireDV.component 7.0.4 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x16549000 - 0x165dcfff com.MOTU.MAS.plugin.AutoPan AutoPan version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0x16613000 - 0x1667efff com.MOTU.MAS.plugin.Chorus Chorus version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0x166ab000 - 0x166e3fff com.MOTU.MAS.plugin.DCNotch DC Notch version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0x16805000 - 0x168dffff com.MOTU.MAS.plugin.Delay Delay version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0x16926000 - 0x1699dfff com.MOTU.MAS.plugin.Dynamics Dynamics version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0x169cb000 - 0x16a32fff com.MOTU.MAS.plugin.Echo Echo version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0x16a5e000 - 0x16b3dfff com.MOTU.MAS.plugin.eVerb eVerb version 4.0.2 (4.0.3) /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0x16b83000 - 0x16bfafff com.MOTU.MAS.plugin.Flanger Flanger version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0x16c2b000 - 0x16c3dfff com.MOTU.MAS.plugin.InvertPhase InvertPhase version 1.0.1, 8/10/03 (1.0.1) /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0x16c4b000 - 0x16c96fff com.MOTU.MAS.plugin.MSDecoder MS Decoder version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0x16cb5000 - 0x16d53fff com.MOTU.MAS.plugin.MultiModeFilter Multimode Filter•„• version 2.0.2 (2.0.3) /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0x16d97000 - 0x16e49fff com.MOTU.MAS.plugin.ParaEQ ParaEQ version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0x16e88000 - 0x16ed9fff com.MOTU.MAS.plugin.QuanJr Quan Jr•„• version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0x17005000 - 0x17079fff com.MOTU.MAS.plugin.Phaser Phaser version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0x170aa000 - 0x17128fff com.MOTU.MAS.plugin.Plate Plate version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0x1715b000 - 0x171f0fff com.MOTU.MAS.plugin.Preamp PreAmp-1 version 3.0.1 (3.0.3) /Library/Audio/Plug-Ins/MAS/PreAmp-1.bundle/Contents/MacOS/PreAmp-1
0x17231000 - 0x17281fff com.MOTU.MAS.plugin.Reverb Reverb version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0x172a1000 - 0x172aafff com.MOTU.MAS.plugin.Reverse Reverse version 1.0.1, 8/10/03 (1.0.1) /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0x172b3000 - 0x17329fff com.MOTU.MAS.plugin.RingMod Ring Modulator version 2.0.2 (2.0.3) /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0x1735b000 - 0x17411fff com.MOTU.MAS.plugin.SonicModulator Sonic Modulator version 3.0.2 (3.0.3) /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0x17463000 - 0x174d1fff com.MOTU.MAS.plugin.Tremolo Tremolo version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0x17500000 - 0x17591fff com.MOTU.MAS.plugin.Trim Trim version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0x189f5000 - 0x18a22fff com.MOTU.plugin.ControlSurface.MackieControl MackieControl version 1.1, 7/24/03 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
0x18ea0000 - 0x18f09fff com.apple.AppleIntermediateCodec 1.0.1 (124) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x18f1e000 - 0x18f97fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x8e995000 - 0x8ea50fff com.apple.QuickTimeMPEG4.component 7.0.4 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x8ec78000 - 0x8ec7bfff com.apple.QuickTimeH264.component 7.0.4 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x8ed72000 - 0x8f731fff com.apple.QuickTimeComponents.component 7.0.4 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x8fa79000 - 0x8fd27fff com.apple.QuickTime 7.0.4 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x8fe00000 - 0x8fe51fff dyld 44.4 /usr/lib/dyld
0x90000000 - 0x901bbfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90213000 - 0x90218fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021a000 - 0x9026dfff com.apple.CoreText 1.0.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9029a000 - 0x9034bfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9037a000 - 0x90734fff com.apple.CoreGraphics 1.258.27 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907c1000 - 0x9089afff com.apple.CoreFoundation 6.4.4 (368.25) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908e3000 - 0x908e3fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e5000 - 0x909e7fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a41000 - 0x90ac5fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aef000 - 0x90b5dfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b74000 - 0x90b86fff libauto.dylib /usr/lib/libauto.dylib
0x90b8d000 - 0x90e65fff com.apple.CoreServices.CarbonCore 681.3 (671.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ecb000 - 0x90f4bfff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f95000 - 0x90fd6fff com.apple.CFNetwork 4.0 (129.13) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90feb000 - 0x91003fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91013000 - 0x91094fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910da000 - 0x91104fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91115000 - 0x91123fff libz.1.dylib /usr/lib/libz.1.dylib
0x91126000 - 0x912e9fff com.apple.security 4.3 (25966) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913ec000 - 0x913f5fff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913fc000 - 0x91423fff com.apple.SystemConfiguration 1.8.2 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91436000 - 0x91441fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91446000 - 0x91466fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x9146c000 - 0x91474fff libbsm.dylib /usr/lib/libbsm.dylib
0x91478000 - 0x914f3fff com.apple.audio.CoreAudio 3.0.3 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91530000 - 0x91530fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91532000 - 0x9156afff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91585000 - 0x91652fff com.apple.ColorSync 4.4.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x916a7000 - 0x91738fff com.apple.print.framework.PrintCore 4.5 (177.10) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9177f000 - 0x91836fff com.apple.QD 3.8.19 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91873000 - 0x918d1fff com.apple.HIServices 1.5.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918ff000 - 0x91923fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91937000 - 0x9195cfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9196f000 - 0x919b1fff com.apple.LaunchServices 168.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x919cd000 - 0x919e1fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919ef000 - 0x91a2efff com.apple.ImageIO.framework 1.4.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a44000 - 0x91b0cfff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b5a000 - 0x91b6ffff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b74000 - 0x91b91fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b96000 - 0x91c05fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c1c000 - 0x91c20fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c22000 - 0x91c69fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91c6e000 - 0x91cabfff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91cb2000 - 0x91ccbfff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91cd0000 - 0x91cd3fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91cd5000 - 0x91cd5fff com.apple.Accelerate 1.2.1 (Accelerate 1.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91cd7000 - 0x91db7fff com.apple.vImage 2.3 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91dbf000 - 0x91ddefff com.apple.Accelerate.vecLib 3.2.1 (vecLib 3.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91e4a000 - 0x91eb8fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91ec3000 - 0x91f57fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91f71000 - 0x924f9fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9252c000 - 0x92857fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92887000 - 0x9290ffff com.apple.DesktopServices 1.3.3 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92950000 - 0x92b7bfff com.apple.Foundation 6.4.5 (567.26) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92c99000 - 0x92d77fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92d97000 - 0x92e85fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92e97000 - 0x92eb5fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92ec0000 - 0x92f1afff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92f38000 - 0x92f38fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92f3a000 - 0x92f4efff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92f66000 - 0x92f76fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92f82000 - 0x92f97fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92fa9000 - 0x93030fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93044000 - 0x9304ffff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93059000 - 0x93086fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x930a0000 - 0x930b0fff com.apple.print.framework.Print 5.0 (190.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x930bc000 - 0x93122fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93153000 - 0x931a2fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x931d0000 - 0x931edfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x931ff000 - 0x9320cfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93215000 - 0x93522fff com.apple.HIToolbox 1.4.6 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93671000 - 0x9367dfff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94160000 - 0x9422afff com.apple.audio.toolbox.AudioToolbox 1.4.1 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9427e000 - 0x9427efff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94280000 - 0x94434fff com.apple.QuartzCore 1.4.7 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x944cc000 - 0x9451cfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x946bf000 - 0x946cefff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x946d6000 - 0x946e2fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94728000 - 0x94740fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94747000 - 0x947b8fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x96708000 - 0x96747fff com.apple.audio.MIDI.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x96b2f000 - 0x96b4efff com.apple.vecLib 3.2.1 (vecLib 3.2.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97354000 - 0x97361fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0xef3b0000 - 0xef49bfff DPPart2.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/DPPart2.dylib
0xef56c000 - 0xef59afff GenericPanes.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/GenericPanes.dylib
0xef5c4000 - 0xef5e7fff DPBasicUI.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/DPBasicUI.dylib
0xef5fc000 - 0xef923fff PerfEngine.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/PerfEngine.dylib
0xefb38000 - 0xefbc3fff MidiSystem /Applications/AudioDesk 2.03.app/Contents/Frameworks/MidiSystem.framework/Versions/A/MidiSystem
0xefcdd000 - 0xefcf9fff XMLLib.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/XMLLib.dylib
0xefd05000 - 0xefd74fff PerfFoundation.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/PerfFoundation.dylib
0xefdcc000 - 0xefdd3fff FileSystemLib.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/FileSystemLib.dylib
0xefdda000 - 0xefe7cfff MotuAudioSystem /Applications/AudioDesk 2.03.app/Contents/Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
0xefed5000 - 0xefed7fff PerfErrorLib.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/PerfErrorLib.dylib
0xefeda000 - 0xefeebfff AllUtilitiesLib.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/AllUtilitiesLib.dylib
0xefef6000 - 0xefefbfff MotuPublicObjects /Applications/AudioDesk 2.03.app/Contents/Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
0xeff01000 - 0xeff65fff OMFImportExport.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/OMFImportExport.dylib
0xeff7a000 - 0xeffa8fff PureDSP.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/PureDSP.dylib
0xeffc2000 - 0xeffecfff MSL_Perf.dylib /Applications/AudioDesk 2.03.app/Contents/MacOS/MSL_Perf.dylib
Model: PowerMac7,3, BootROM 5.2.4f1, 2 processors, PowerPC G5 (3.1), 2 GHz, 2.5 GB
Graphics: ATI Radeon 9650, ATY,RV351, AGP, 256 MB
Memory Module: DIMM0/J11, 256 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM1/J12, 256 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM2/J13, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM3/J14, 1 GB, DDR SDRAM, PC3200U-30330
Network Service: Built-in Ethernet, Ethernet, en0
PCI Card: pci137a,4, sppci_audio, SLOT-3
Serial ATA Device: Hitachi HDS724040KLSA80, 372.61 GB
Parallel ATA Device: SONY DVD RW DW-Q28A, 3.4 GB
USB Device: XSKey, Emagic GmbH, Up to 1.5 Mb/sec, 500 mA
USB Device: Hub, , Up to 12 Mb/sec, 500 mA
USB Device: USB-PS/2 Mouse M-BA47, Logitech, Up to 1.5 Mb/sec, 100 mA
USB Device: Microsoft Natural Keyboard Pro, , Up to 1.5 Mb/sec, 100 mA
USB Device: Studio Display, , Up to 1.5 Mb/sec, 500 mA
Report Version: 4
Command: AudioDesk
PID: 203
Thread: 9
Thread 0:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9 Crashed:
Thread 10:
Thread 11:
- iMAS
This is probably a dumb question and I'm not trying to belittle you or anything...but did you set up all your i/o's in "Motu PCI audio Setup ?"sbugaj wrote:Well, my card was seen and all that. And in Audio Desk I can prep a track for recording, monitor that channel with Studio -> Audio Monitor and see signal, but when I try to record Audio Desk just quits
...and also in "utilitles>audio/MIDI setup" and tried playing audio (like iTUNES) through the unit ?
The manual suggests that you install the pci424 driver and test the hardware unit first before installing and using it w/ software.
He's got a 372Gig drive and two and a half Gigs of RAM. I don't think it's possible.iMAS wrote:I'm not trying to belittle you or anything...
sbugaj,
Sorry, I may be out of this one, as my last G4 stayed on 9.1 (I'm mainly PC now). It does sound "hardware'ish", but iMAS' suggestion on seeing it run outside of AudioDesk is a good one (one less suspect maybe). Then, the usual cable swaps and driver versions, and maybe a non-MOTU host app to see if there's a difference. I'm guessing you were running a "simple" clock config (PCI424 internal master). I'd also wonder if all the available console/pref. settings seem to be working, before you start running a DAW app. Like, if you change rate, clock or i/o prefs in the console, and/or mess with CueMix routing, does the 24io seem to respond accordingly, or is it already "unstable"? Lastly, if you could temporarily toss it in a different machine (of either platform), you could at least figure out whether you needed to start working on getting an RMA or whatever. If all goes well, and it works there, see if you can find someone with the same card on that same G5 (ideally, along with the slot used), and start back at the OS/software angle. If you can ever get MOTU, I guess you could at least get a verification on the Mac/card combo.
Sorry for the obvious suggestions, and hope it works out,
George
