Questions about DP 3.0 on OS 9
Shixapatrol
Post by Shixapatrol »
I have a few questions??....and I'll prioritize them to make this easy.
I run DP3 on OS 9.somthing. I do this becauseI like OS 9 better than OSX (it seems faster) and I'm too poor/cheap to upgrade. I record primarily live audio, but often track MIDI drums using a TD-10, a MOTU2408 and a Midiman hooked up to a Mac G4 733hz.
Question 1. Can I search this site or better narrow my search for things only pertaining to DP3? or.... is there another site that only catalogs that version
Question 2. Is there a vast difference between DP3 and the current DP with my applications in mind?
Question 3. What is the cheapest way to add analog inputs to the 2408....A used A-DAT???
Thanks Guys.
tdblanchard
dp3
Post by tdblanchard »
i ran dp3 for years and loved loved loved it.
then i finally made the transition to osx and dp4..then4.6 and holy bubbliscious!
anyway, you didn't ask for a review on dp4.
get an 828. used or new. i still have my original one that i got with my dp3 set-up. i also have a yamaha 01v board with the ADAT card, so i can go digitally 8 in and out using the 828. with eight channels of balanced/unbalanced analog input and output using 24-bit converters with 105 dB dynamic range, eight channels of 24-bit ADAT lightpipe and stereo S/PDIF I/O, the 828 provides a grand total of 18 simultaneous inputs and outputs.
the thing rox.
good luck and when you decide to make the leap, you won't regret a penny spent.
not much support out there for the old schoolies. sorry.
DP 6 (not installed) | MX4 | Reason | Symphonic Instrument | BFD2 | Mac Pro 8-Core 2.26 12GB RAM | "old school" 828 | Yamaha 01v | Digidesign 003 | Pro Tools 8 LE | '72 Fender Strat | http://www.superflydisco.com
emulatorloo
Re: Questions about DP 3.0 on OS 9
Post by emulatorloo »
Shixapatrol wrote:Question 3. What is the cheapest way to add analog inputs to the 2408....A used A-DAT???
A broken adat on ebay, maybe. another option behringer ADA8000?:
http://www.zzounds.com/item--BEHADA8000
pencilina
Post by pencilina »
good for you stick with os9 - DP3 works great.
used adats r awesome with your 2408 (I have three w/mine) - transport doesn't need to work just make sure i/o is ok
If you need one PM me and I might have a good spare I can sell you
