Hi Guys,
If you have some problem using the DXi version in Sonar
especially the stuck note problem, I'll advice you to use the VST version.
It works like a charm. I'm using sonar 4 and MSI without any problem.
It seems that others here, I've done the same thing with success.
Sonar don't even use DXi natively so why not use a perfectly working
plugin format. It even seems faster.
Hope this helps.
Regards,
Problem Sonar and DXi Version: Use VST version
DXi or VST
I agree. The VST plug-in works the best for me too.
I pulled my hair out originally trying to get MSI to work in Sonar. The ONLY way I can get it to work acceptably is with VST in 96khz. No dice with DXi, or at 44.1, which I guess is ok, because I prefer to work in 96 when my PC can handle it and at the moment it seems to.
Of course stupid me upgraded to 1.1.1 and now it doesn't work at all (can't load my projects). New rule. Never. Upgrade. Anything.
