Converting MIDI to Audio
rmhofu
Post by rmhofu »
:oops: I know this is probably regarded as a really dumb question, but I am laying some really beautiful MIDI sequences. I however, have no idea how I can convert them into audio. I am sure it's probably very simple, but I can't find how to do it anywhere. Can somebody please help me.
Roy
1 - "If it ain't broke, don't fix it, but if something BETTER comes along, then make the change".
2 - "If it was easy, then everybody would do it, if you want to be good at it, then slave for it"
3 - "Passion always finds a way"
chrispick
Post by chrispick »
If I understand your situation correctly: Check your manual for "freeze tracks" or routing and recording to audio tracks.
npatton
Post by npatton »
Are you using hardware synths or software?
Mac Pro (Late 2013) (3.5 GHz 6-Core Intel Xeon E5, 32 GB RAM) OS 10.13.6
MacBook Pro (2 GHz Intel Core i7, 8 gigs RAM); OSX10.11.6; DP 10.13; Unisyn 2.1.1; Stylus RMX; MOTU MIDI Express XT; MOTU 828x; Kurzweil PC3 with Kore 64; Roland XV-5050, D-50; Alesis QS7; Yamaha S90ES, TX-216; Hammond XK-3
FWIW, my own music can be heard at...
http://www.neilpatton.net
http://http://www.pandora.com/neil-patton
Business Site: http://www.pattonmusic.com
billf
Post by billf »
More info will help. What version of DP? What's your configuration?
buzzsmith
Post by buzzsmith »
This was recently discussed at length...
check out
http://www.motunation.com/forum/viewtop ... ght=#68229
=bz=
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
rmhofu
Post by rmhofu »
Thanks everybody for your responses. I am using DP 4.6 with software both soft and hard synths, Kurzweil PC2, Halion Player, Groove Agent. Freezing seems to work and another option I have been given is to record the audio output of the MIDI/audio module onto an audio track. I am having difficulty doing this without having to mute all other tracks and picking up the audio at my main outputs (analog 1 & 2 on a Motu Traveler). Any solutions :?:
billf
Post by billf »
rmhofu wrote:Thanks everybody for your responses. I am using DP 4.6 with software both soft and hard synths, Kurzweil PC2, Halion Player, Groove Agent. Freezing seems to work and another option I have been given is to record the audio output of the MIDI/audio module onto an audio track. I am having difficulty doing this without having to mute all other tracks and picking up the audio at my main outputs (analog 1 & 2 on a Motu Traveler). Any solutions :?:
It sounds like you have a routing issue.
For soft synths:
http://www.motu.com/techsupport/technot ... erm=freeze
For hardware synths, you have to arm an audio track to record, make sure the input column of the audio shows the appropriate analog inputs from the traveller.
You should not have to mute other tracks to record audio. The traveller should come with a manual showing various setup options, and DP setup options might be in there.
rmhofu
Post by rmhofu »
Thanks a lot, am off to the studio to give this a try. You are right, it's routing problem that I have. I essentially know where my signal is and where I want to take it, but am having a bit of difficulty understanding the instrument track and even the aux track.
Roy
