Re-phrased question about pedal steel guitar
fender3
Post by fender3 »
Does anyone know, using mach 5, how to get a sound like a pedal steel giutar? I already have some good MIDI licks. I am just trying to find a way to make a pedal steel guitar sound.
I have a Mac G5 dual hard drive. I am on Tiger. I am currently using a Kurzweil PC3X Synth to a motu828mkII. I am using the Dp 6 with the machfive2 sampler, waves gold bundle, and altiverb reverb unit. Studio Monitors are Mackie 824s. Rode NTK condenser mic.
buzzsmith
Post by buzzsmith »
I can't tell you specifically about Mach 5 (which instrument) but I can offer the possible insight that a pedal steel gets a lot of it's characteristic sound because you can bend notes within a chord.
Some solutions I've seen include using the same patch on say 3 different MIDI channels of a VI / module.
Channel 1: top note of chord
Channel 2: middle note and "bendable" via pitch wheel
Channel 3: bottom note of chord.
With this, the pitch bend only affects the note you want to slide and leaves the other 2 notes alone.
Or if you wanted to slide, say, from a G to a C chord within a measure...
Channel 1: G (whole note)
Channel 2: D pitch bend up a whole step to E (to sound like 2 half notes)
Channel 3: B pitch bend up a half step to C (to sound like 2 half notes)
...etc.
Hope this helps!
=bz=
(I've actually found it a lot more time efficient to hire a steel guitarist!)
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
