That would be good news. It means if I wanted to expand my analog I/O, I would just daisy chain one in between my 828es and my 24i and not need to shell out $500 or whatever for a MOTU AVB Switch.MartinBaird wrote:If it says the new 16A has an AVB switch, I can't imagine it doesn't support all AVB interfaces.
MB
New MOTU AVB Interface!! - The 16A
Re: New MOTU AVB Interface!! - The 16A
I wonder if they run cooler than the last generation.
I've heard many reports over the years of them frying, due apparently to the convertors.
White Sea Studio (the "snake oil guy")for example had 3 units running and at least 2 of them fried themselves. I've seen footage that clearly shows 1 empty rack space above and below each unit.
I remember when they first appeared around 2015 IIRC that folks were concerned about how hot they ran. I therefore expected this sort of thing to happen as the years rolled on.
MOTU would no doubt have been aware of the situation so yeah, I wonder if it's been addressed.
- PhireAlly
The previous generation was vented on the lower portion of the sides.
The new generation however, seem to have strategically placed top vents. That possibly could be part of addressing the heat situation.
I do have half of a rack space above all of my MOTU interfaces and a slow running fan to move some hot air when all of my hardware are in use.
10 years problem free !!
"So lets knock knock knock, on wood"
PhireAlly
MacMini M1, 8-Core @ 3.2GHz, 16GB Ram, MacOS 14.7.5 (Sonoma)
MOTU 1248 - MOTU 16A (2014)- MOTU 8A - Antelope Audio Zen Q - Arturia AudioFuse (Rev 1)- UA Apollo Solo
MOTU DP 11.3.4 - Studio One Pro 6.6.4 - Logic Pro 11 - Nuendo 14
Acustica - Antares - Apogee - Arturia - Blue Cat - Boz Digital - Celemony - Eventide - FabFilter - Flux
HorNet - IK - iZotope - Kazrog - McDSP - Melda - Nomad Factory
Plugin Alliance - Softube - Soundtoys - Tokyo Dawn - UAD-2_TB2 & PCIe
Valhalla - Waves v14
A-ha! Thanks PA.
Yeah, it looks like they've gone with taller side-slots and if those are holes on the top (they look like holes, only they're tiny), are no doubt expecting accelerated convection as the unit warms up.
I had two older 16As that developed serious problems (one repairable, one not) because of heat, as well as a 1248 that completely fried and couldn’t be repaired by my local tech shop. I left them on a lot in the rack with no spacing between them. They used to get really hot…I should have known better.PhireAlly wrote: ↑Wed Apr 02, 2025 12:27 amThe previous generation was vented on the lower portion of the sides.
PhireAlly
Anyway, after repairing one 16A and buying a replacement used, I installed them in the rack with a 1/2 space between them. No problems since.
Mac Studio | 96 GB RAM | OS 15.4 | LIVE 12 | CUBASE 14 | DP 11 | MOTU Interfaces | Waaay Waaay Too Many Plug-ins (but I'm improving!)|
http://www.gesslr.com
Deeper unit with some vent holes on top, should be better heat management. I bet it still needs open space above and below.
USB 4 will solve the old TB to USB-C adapter problems.
The line in and out look like they are unity throughput again, thank God. The previous were offset by something like 3.74dB, couldn't set it to unity.
The patching looks like it will be easier for most people to understand. It may feel more difficult to people who grasp Dante routing or the old way clearly.
Not sure this Cuemix Pro is any different from the previous AVB mixer. Would be great if direct hardware playthrough is back.
I paid $1380 for the previous version 11 years ago, so nothing shocking about $1495.
No manual PDF available yet.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
- PhireAlly
The 1st generation MOTU AVB devices use the “legacy” AM824 AVB stream format (which is 24bit)James Steele wrote: ↑Tue Apr 01, 2025 3:21 pmMakes me wonder if it might be possible to daisy chain it with other MOTU AVB interfaces and thus not need to buy an AVB switch if I wanted to integrate it into my 828es + 24Ai setup?mikehalloran wrote:I see a second Ethernet port on the new.
The new generation can use either the “legacy” stream format or the AAF stream format (which is capable of 32bit or 24bit)
My guess is, to ensure compatibility between the older and newer AVB devices, MOTU would have to employ some automatic switching in the new generation devices or maybe manual switching in the CueMix Pro app to have all devices use the same stream.
My understanding is that all devices on the Network must use the same stream format.
Just thinking out loud,
PhireAlly
That's the great thing about "standards"—there are so many of them!
- PhireAlly
Found definitive answers to the device compatibility questions.
From the MOTU 16A (2025) product page ....
Additional features (Excerpt)
The new 16A is AVB-compatible with all other MOTU AVB interfaces.
Each audio stream can be individually configured between 1-8 audio channels.
Supports AAF stream formats and the legacy AM8-24 format, configurable per stream.
So manual configuration it is.
That's pretty cool.
You can determine which streams go to older generation AVB devices and which streams go to the newer generation AVB devices on the same Network ,,,, Awesome!
Great Job MOTU !!
PhireAlly
That's pretty cool.
Great Job MOTU !!
PhireAlly
- PhireAlly
But wait ... There's more
The built-In AVB switch in the (2025) 16A allows for up to 8 devices to be daisy chained !!
That's 7 "hops"
No external AVB switch required.
Sweet !!!
PhireAlly
That's 7 "hops"
Sweet !!!
PhireAlly
The old AVB devices report in AudioMIDI as 32 bit streams via USB and TB.
I’ll have to hook up via ethernet again and see what it says.
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
New Cuemix doesn't see my old 16A. Big bummer, that web app really sucks.
- PhireAlly
Hey Doug
I’m not 100% certain but AudioMidi setup could possibly be reporting the DAC streams and not the AVB streams.
I’d have to check the Apple AVDECC configuration to see if it reports differently from AudioMidi setup.
But all of my research points to the following…
AM824 formats only support 24 bits per sample.
AAF formats allow packed 16 bits, 24 bits, and 32 bits per sample.
For Floating point stream formats, choose 32 bits per sample.
Hope this helps
PhireAlly
It would be great if the new Cue Mix could be made to work with the older interfaces. It looks friendlier...
I'm not a fan, either. Really wish the older interfaces worked with an actual purpose built application.
