Re: Plugin Alliance Lindell 50 Series updated to 1.0.4
James Steele wrote: Fri Jan 10, 2025 11:20 amit's a hassle to have to go to the Plugin Alliance site and compare version numbers of my installed plugs
I’m finding the KVR Studio Manager helps a but. It misses a few things but saves some time.
Newfangled "Obliterate" Distortion Filter Plugin updated to 1.0.3
This is a free plugin. It was updated to 1.0.3. Not sure when, but if you have 1.0.2 get it. :)
https://www.eventideaudio.com/plug-ins/obliterate/
APU Software Updates
APU Loudness Series updated to 3.2.6
https://apu.software/download/
Version 3.2.6
Fix offline rendering performance issue
Twisted Wave updated to 28.13
Fixed
TwistedWave would show an error message when trying to install a TwistedWave 29+ license key.
iLok License Manager updated to 5.10.0
Version 5.10.0 GM (b5256, 869c108c), January 08, 2025:
Improved Enhancements to iLok Cloud connection reliability.
Improved In iLok License Manager, Export CSV button enabling and disabling when moving between different views.
Fixed Fixed a crash in iLok License Manager when running on slow, under-provisioned Windows systems.
Fixed Spaces after commas or periods were not being rendered correctly on the Mac in the Activation Experience.
corbo-billy
Post by corbo-billy »
Drumazon 2 updated to version 2.0.7.
Fixed
_ Problem with recalling sessions made with early versions
_ Audio artifacts appearing in cymbal instruments .
Sigmund 2 updated to version 2.0.1.
Fixed:
_ Possible crashes with Lin/Log modulation active and negative amounts .
Console 1 System updated to 2.5.98
Change log for 2.5.97 and 2.5.98 (Released on January 14th, 2025)
New product:
Dimensions
Console 1 System
Fixed an issue that could cause the On-Screen Display to crash in Compact mode when removing a Console 1 plug-in instance (for instance by removing a track).
Changed so that the MIDI CC modules are not possible to load unless a Mk III HW unit (either Console 1 Channel Mk III or Console 1 Fader Mk III) is connected since modules will not work otherwise.
IK Multimedia Syntronik 2 updated to 2.1.2
Changes from version 2.1.1:
Fixed an issue where saving a DAW session would not save custom waveforms selection
Fixed browser not retaining favorites and search text when closing and re-opening the UI
Fixed a crash when using the Flexi Amp effect at 96 kHz
Fixed an issue where duplicating Syntronik instances wouldn't retain custom waveforms
General reliability Improvements
UPDATE: IK Product Manager seems to be downloading version 2.1.1 instead. Tried multiple times.
Addictive Drums 2.5.3 updated to 2.5.4
Addictive Drums 2.5.4- Jan 16, 2025
Tuned cloud sync handling
UVI Xtreme FX 2 updated to 1.0.3
1.0.3
- Fix: issue when reloading user samples
- Fix: "Magical" scene loading using the internal browser
- Fix: click in "Roomtones_Buzz_3"
D16 Group Repeater updated to 1.2.3
https://d16.pl/repeater
Following changes have been made since version 1.2.2
Fixed
• Problems with few models' sound in sample rates higher than 44KHz
Changed
• Code maintenance
Just FYI, the UVI update dropped 9 months ago James.
Thank you for the heads-up for those who haven't seen it yet, of course. :headbang:
Re: UVI Xtreme FX 2 updated to 1.0.3
monkey man wrote: Thu Jan 16, 2025 7:27 pm Just FYI, the UVI update dropped 9 months ago James.
That's really strange that XTremeFX 1.0.3 was released 9 months ago, because I have ran UVI Portal at least every other day for the last 9 months and this is the first time it notified me that it needed to be updated. Weird, huh? Really strange to me that UVI Portal would say nothing to me for the last 6 months or more without notifying me that my 1.0.2 was out of date. I wrote UVI Support to ask when 1.0.3 dropped.
Something didn't seem right. So I checked my log. Yes... I keep a text file and make an entry every time I install or update a plug-in or library or run a Time Machine backup so I can figure out if a particular plugin caused instability. According to my log here are the entries when I searched Xtreme FX 2:
04/08/24 11:04pm Installed Xtreme FX 2 1.0.1 update (corrected missing samples)
04/09/24 9:53pm Updated UVI Xtreme FX 2 1.0.1 to 1.0.2
01/16/25 7:00pm Updated UVI XtremeFX 2 Library to 1.0.3
It looks like 1.0.2 dropped 9 months ago. It appears that 1.0.3 IS actually new. Just an FYI. :wink:
Interesting James.
My records show that 1.0.2 dropped in March last year and that 1.0.3 followed a month later in April.
I'd already checked this before I posted.
I don't run "Portal"; I do everything manually.
The download page says 10th April last year:
Screen Shot 2025-01-17 at 2.54.03 pm.jpg (43.4 KiB) Viewed 1978 times
Strange that the Portal software told you a different story.
Anywho, thank you once again for everything that you do for us mate.
