The SSL takeover was a hot mess. I’ve washed my hands of it and refuse to throw any more money at Harrison. Good money after bad.bayswater wrote: ↑Tue Dec 10, 2024 9:59 am ... or lack of update in the case of Harrison 32C-Channel. KVR said there is a version newer than the one I have, but I couldn't find it. SSL cheerfully replied that it is discontinued. There is a new plugin to replace it priced at about $1000 with 85% off sales. I found the old one useful as a starting point and I'm disappointed at what has happened at Harrison with the SSL takeover.
Re: Harrison 32C-Channel
NI Komplete Kontrol updated to 3.3.4
Personally I'm staying behind on 2.9.6, but for those interested there's an update.
Version 3.3.4 2024-12-10
FIXED
an issue that would cause Kontakt 7 and some other Plugin Uls not to load correctly when closing and opening them
Default Folder updated to 6.1.3
Posting this here, because this is a popular utility and often times you have to do the check for updates thing in order to find out about updates with this utility.
Version 6.1.3:
• Eliminated a crash that could occur upon opening a file dialog when tag information in your Finder settings was corrupted or missing.
• Fixed a bug that could result in crashes when the macOS window server delivered unexpected or erroneous data.
• Correctly detect Sequoia save dialogs that include a format popup (such as when saving RTF files in TextEdit).
• Default Folder X accurately tracks recent Microsoft Word documents stored on OneDrive and Sharepoint.
• Fixed a bug that could cause crashes when closing previews of certain media files.
• The construction of Default Folder X's hierarchical menus is faster.
• Fixed a crash that could occur when quitting Default Folder X.
• You can now bring up the Quick Search window using AppleScript or Shortcuts.
• The "defaultfolderx" URL scheme can be used to bring up Default Folder X's menu, Quick Search window, Finder drawer, and settings. These URLs will work after installing version 6.1.3:
defaultfolderx://Menu
defaultfolderx://QuickSearch
defaultfolderx://Drawer
defaultfolderx://Settings
Can’t disagree. After the takeover I was optimistic and updated Mixbus to V10. It was inexpensive but since then it has been on sale for $15. Seems like an act of desperation if not a complete retreat
mikehalloran wrote: ↑Tue Dec 10, 2024 10:21 amThe SSL takeover was a hot mess. I’ve washed my hands of it and refuse to throw any more money at Harrison. Good money after bad.bayswater wrote: ↑Tue Dec 10, 2024 9:59 am ... or lack of update in the case of Harrison 32C-Channel. KVR said there is a version newer than the one I have, but I couldn't find it. SSL cheerfully replied that it is discontinued. There is a new plugin to replace it priced at about $1000 with 85% off sales. I found the old one useful as a starting point and I'm disappointed at what has happened at Harrison with the SSL takeover.
Melodyne 5.4.2 is out — all versions
If you do not update, next time you go to use Melodyne, it will open your browser and direct you to the download screen—where you can update or dismiss. This drove me nuts until I realized that my version was out of date. Once I updated, that went away. This time I was proactive.
We have just released Melodyne 5.4.2. This is a free update containing, in addition to various optimizations and bug fixes, an important adaptation to macOS Sequoia.
macOS Sequoia: Previously, the function “Private Wi-Fi Address” made it necessary to reactivate Melodyne. With Melodyne 5.4.2, the function can be used free from any such inconvenience.
macOS in general: Scrolling with the trackpad has been revised and improved.
macOS in general: Changing to another program sometimes gave rise to graphic artifacts.
ARA and plug-in: Under certain circumstances, opening Melodyne could lead to a crash.
We recommend this free update to all users. It is available for download in your user account.
- corbo-billy
With MacOS 15.2 Sequoia, Digital Performer 11 work fine _
T-RackS 6 MAX updated to 6.1.1
Modules: size optimisation
Space Delay: improved stability on Bitwig
Triad Chorus: changed category to Other
Mastering Console: improved stability
IK Multimedia Lurssen Mastering Console updated to 1.2
What's new:
• added official Apple Silicon architecture support, the minimum required macOS version is now 10.13
• added high res images and UI scaling
• added AAX Page Table support also on Windows and fixed UI not updating to MONO when changing channel configurations in the DAW’s channel strip settings
• Standalone: improved stability
• Installer: added plugin type selection to the macOS installer and total size reduction
Audio Hijack updated from 4.4.4 to 4.4.5
Updated in Audio Hijack 4.4.5:
• Clicking a menu bar meter will now bring its associated session forward. Handy!
• Updates have been made to Audio Hijack’s user interface framework. Please contact us if you notice any interface issues.
• The “Finder” special source will no longer incorrectly receive audio when previewing inside another app’s “Open” dialog.
• Loading a session which contains visible third-party Audio Unit popovers will no longer potentially lead to a deadlock.
• Issues with the animation of the “Time Shift” block’s slider have been corrected.
• Menu bar meters are now properly removed when their associated block is deleted.
• Text styling is now correctly stripped when pasting text into Audio Hijack’s various text fields.
• A drawing bug affected unchecked checkboxes on MacOS 15 (Sequoia) has been corrected.
NI Massive and Massive X updated
Back after a couple of days off. Here are some Native Instruments updates from a couple of days ago:
Massive X updated to 1.4.5:
Massive updated to 1.7.0:
Version 1.4.5 2024-12-16
FIXED
Massive X is now macOS Sequoia compatible
ADDED
User defined tags can now be added to presets
ADDED
Splice licensing support
KNOWN ISSUE
Graphical anomalies can be observed when switching presets in browser and when saving user tags
Version 1.7.0 2024-12-16
Please note: this is the last version of Massive that ships a VST2 target. We recommend to use VST3 whenever you can.
FIXED
Massive is now macOS Sequoia compatible
ADDED
Scalable user interface
ADDED
Steinberg Media Bay updates to 1.2.20
Running Steinberg Download Manager will update Media Bay to 1.2.20
- corbo-billy
Arturia MiniFreak update in version 3.O (soft & harware)
Arturia MiniFreak update in version 3.O (soft & harware) :
New Sample-based engines: 7 Granular engines and 1 classic Sample engine
KeyLab mk3 Integration
Improved MIDI configurations allowing the user to save his own default settings per controller
Created new default MIDI mappings for MiniLab 3 and KeyLabs, ensuring consistent assignments for all instruments
Added NKS 2 compatibility
New Master volume knob that reacts to CC7 (only on software)
Preset volume has been moved to the side panel
Sidepanel option to save the octave transpose in presets
IK Multimedia MixBox 1.5.0 updated to 1.5.1
What's New in v1.5.1:
Minimum required macOS version is now 10.13
Reduced installer size
Fixed an issue where the plugin version would appear blurry on Windows when DPI scaling is higher than 100%
Added the possibility to select what plug-in formats to install on macOS
General reliability improvements
IK Multimedia Hammond B-3X updated to 1.3.5
What’s New in Hammond B-3X 1.3.5
Improved startup time
Added support for Hammond SK Pro series models
Fixed a graphical glitch when switching Leslie models
APU Software Updates
APU Loudness Series updated to 3.2.1
https://apu.software/download/
Version 3.2.1
Fix dials not always updating
