The free VI's/plugs list.
Lifeline Expanse Lite (MultiFX) - FREE with coupon code
https://www.pluginboutique.com/products ... panse-Lite
Use code KVR0824 at checkout.
UA Century Tube Channel Strip - FREE
Re: UA Century Tube Channel Strip - FREE
Sounds very nice. But the meters are odd. At low levels with not much effect, and no audible distortion, the output meter is pinned at +3.James Steele wrote: ↑Thu Aug 15, 2024 11:24 pm UA Century Tube Channel Strip - FREE
https://www.uaudio.com/free-century-tube-plugin
Yep.... I don't know. Don't download then. I just take my time posting these things for the benefit of users. I don't test them all.bayswater wrote: ↑Fri Aug 16, 2024 3:24 pmSounds very nice. But the meters are odd. At low levels with not much effect, and no audible distortion, the output meter is pinned at +3.James Steele wrote: ↑Thu Aug 15, 2024 11:24 pm UA Century Tube Channel Strip - FREE
Free Audio Loops from ModeAudio/Tracktion
Got this email with a link to some freebie loops and SFX... drum hits, etc. Royalty free. Download and check them out... trash them if you don't like 'em. I don't care.
https://newsletter.tracktion.com/l/gJ92 ... IcR763drkw
Right. I wasn’t expecting you to answer. It was just there for anyone who might try it and have some thoughts.James Steele wrote: ↑Mon Aug 26, 2024 6:02 pm Yep.... I don't know. Don't download then. I just take my time posting these things for the benefit of users. I don't test them all.![]()
Brainworx bx_meter is now FREE
Re: Brainworx bx_meter is now FREE
I’ve had it for quite a while, but as mentioned elsewhere it eats a lot of CPU on my setup. I’ve tried to replace it but can’t find anything I like as much. How heavy is it on your system?Rick Cornish wrote: ↑Tue Sep 03, 2024 12:20 pm Maybe the best meter out there. I use it on every mix. And now it's FREE.
Get it here
You're right, bx_meter is often near the top of my Effect Performance window, but I’ve never felt like it was noticeably dogging my machine… even on my old (“trashcan”) Mac Pro. On my M2 Mac Studio, I don’t even think about it.
I set up a custom preset on the bx with the meter K-weighted at -14dB and peak meters set to hold so I'm sure to catch any overs. I also run the really nice PSP Triple Meter in RMS mode to watch the averages and have a hardware Dorrough A2 on my outputs for confirmation (and the pretty lights
It’s only one instance. I’ll put it back and live with the CPU meters.Rick Cornish wrote: ↑Tue Sep 03, 2024 6:35 pm You're right, bx_meter is often near the top of my Effect Performance window, but I’ve never felt like it was noticeably dogging my machine… even on my old (“trashcan”) Mac Pro. On my M2 Mac Studio, I don’t even think about it.
Get Arturia Delay TAPE-201 FREE
As of 4:07pm PDT on 9/4, this was still working. I just checked (already have it though). Found this on another forum.
Go to this link:
https://www.pluginboutique.com/products ... eXxtxhb0zC
When you check out use this coupon code: fcyk3f3b
Don't bother adding the "free gift" when you check out as using the coupon will remove it anyway.
Go to this link:
Modalics Plugin Buddy (FREE)
https://www.modalics.com/products/plugin-buddy-free
Just came across a post about this on another forum. It's like a very stripped down Blue Cat PatchWork but it can do a very useful thing, which is let you use a different format plugin than your DAW may support, as well as allow you to build a chain of plugs. Also supports MIDI effect and has some free plugs built in.
8Dio Plucked Grand Piano (FREE Kontakt Instrument)
https://8dio.com/products/the-new-plucked-grand-piano
Requires full version of Kontakt 5.8.1 or later.
Re: The free VI's/plugs list.
A very nice verb. Installation and registration was...odd. Needs the Ujam installer application.bayswater wrote: ↑Tue Sep 24, 2024 8:35 am Free reverb from UJAM
https://www.soundonsound.com/news/ujam- ... 31-october
