Hello,
Is it possible to set the mixing console in DP with a command to zero?
So that all plugins and automation are taken out?
I would like to start the mix of zero again.
Greetings. Denis
Set the mixing console in DP with a command to zero.
G4 1,6 GHz Dual MDD, 2GB RAM, osx10.3.9; Logic 7.1.1; Pro Tools 6.41 Mix +, MacPro, DP 10.11, Logic X, Melodyne, EZdrummer, V.Guitarist-2,Raging Guitars, NI Komplete, Roland JV2080,S760, ATARI STE,...
Re: Set the mixing console in DP with a command to zero.
Starting a New Mix might do what you want. Little menu at the bottom left of the Mixer window.
Hello bayswater,
thank you! That's exactly what I was looking for. Saving or deleting the mix is well solved in DP.
Have a nice day, Denis
PS.
Not on the topic... but I don't know why in my post 3 is displayed instead of 11... no matter
PS.
