Hi all, as the title indicates I am no longer able to select all files/automation in my timeline/sequence when I want to bounce to disk since I upgraded to Sonoma yesterday. I am on DP 11.31.
Anyone else had this issue? Am I missing something?
Can no longer do "select all" to select files in my timeline after upgrading to Sonoma
Re: Can no longer do "select all" to select files in my timeline after upgrading to Sonoma
Can you show us a screen shot of what you are trying to do?
Did the Sonoma upgrade put you at 14.4.1? Sometimes the .1 update needs to be run separately.
Yes, I am indeed at 14.4.1.
This screencap shows the timeline before I attempt to do "select all" (command+A)
And this one shows what happens when I "select all"
It's not super obvious from the screencap but "select all" ends up only selecting the tracks/channels (you can see that they have been made a bit darker to show they've been selected), but it doesn't select the audio files+automation featured in each track. Been using DP now for over 20 years and this is the first time this happens to me...
So I'm just now realizing that this might have something to do with the fact that this particular session I'm working on was started on an earlier version of DP over a year ago; I just tried selecting everything in my timeline/sequence in an another more recent session and there was no trouble at all. Everything was working as usual...
Strange...
Strange...
- primeevolutionary
I believe that it might be that you don't have any numbers in the Selection Information fields. They're showing 0:00:00.00 for start and finish.
Macmini9,1 (M1, 2020) 16 GB RAM
MacBookPro15,1 2.6 GHz 6-Core (Intel, 2018) 16 GB RAM
OS X 14.5
DP11.31
2 896 mk3 192 kHz Hybrid FW • USB2
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
