Behringer X-Touch....HUI or MCU?
darrell
Post by darrell »
Hi all,
Just indulged in some retail therapy and bought a Behringer X-Touch. Will it run better under DP11 with HUI or MCU control? Does DP even support HUI?
Killahurts
Re: Behringer X-Touch....HUI or MCU?
Post by Killahurts »
I would use MCU with DP.
My console is a controller- I use MCU with DP, and HUI for Pro Tools. I wouldn't use HUI for anything else than Pro Tools, because there are certain limitations with it for other DAWs. HUI was the first of all these formats back in the day, and it's sort of an old dog.
If my Matrix console supported Avid's EuCon (or whatever it's called now) I would use that for PT, but I would likely still use MCU for DP, because it is solid and dependable.. MOTU also updated the MCU protocol for DP a year or two ago, works much better now.
dwilliams
Post by dwilliams »
MCU. I have a spreadsheet where I mapped out every behavior of each option. I will post it later.
Note, there is "MCU" and "MCU Compatible". I don’t remember which is which. I will look it up.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 16" M3 Max 16-core 4.05 GHz 48GB 1TB Late 2023 MBP, Sonoma 14.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2, TB hub w/ USB 3.0 drives; USB 3.0: Softube Console 1 Mk3, Stream Deck XL; USB 2.0: SSL UC1, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; , M Audio Oxygen 49, Akai MPD218, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.32
dwilliams
Post by dwilliams »
As I said, I can't attach the spreadsheet where I mapped out everything to the best of my ability, including the HUI profile, but here is the bread and butter of it. As you can note, I went with "MCU Compatible". Enjoy your X-Touch. I paid $3,500 for my actual HUI in 1999. Faders started chattering fairly soon and it failed in a couple of years. I only paid $350 for my X-Touch I've had it for two years and it is working fine. BTW, I started with 16 faders, but ditched the expander to make room for an SSL UC1. I don't miss them at all. 8 faders gets the job done.
Screenshot 2024-02-16 at 4.27.54 PM.png (93.54 KiB) Viewed 280 times
Screenshot 2024-02-16 at 4.27.41 PM.png (108.12 KiB) Viewed 280 times
DP Button Layout.jpg (2.39 MiB) Viewed 280 times
Krakadon
aka Dave Williams
* DP 11.32
