Custom key commands - a cautionary tale
crduval
Post by crduval »
Hi folks;
Just had an experience that I thought I'd relate in case this happens to you.
I recently noticed that one of the keys (F#3) on my MIDI controller was no longer recording MIDI data into DP. Just the one note.
My first thought was that my controller had a problem, most likely a guitar pick that had fallen into the keybed or something, so I got ready to open it up and check. But thankfully, before I did, I switched the synth over to local control just to verify that the key mechanism wasn't working. But the key worked fine playing the internal synth sounds. Based on how that hardware works, I couldn't imagine a scenario where a single key would trigger the internal sounds but not send MIDI data. It made no sense.
I then checked, and found that MIDI data was indeed being received by my interface from that key. Checking DP's MIDI monitor, I saw that DP could see the data come in as well - but still that note did not work.
I called up the Input filter, expecting to see somehow that I had excluded that particular key, but that wasn't it. Then I manually pencilled in the suspect note in the MIDI editor, and that worked fine- therefore it wasn't some kind of MIDI note muting.
At that point, I was flummoxed - until I remembered that I had recently watched one of the DP video seminars that talked about setting custom key combinations for DP functions. After seeing that video, I played with setting up a few custom commands of my own.
I checked, and sure enough, while I had been working to customize a few commands, I must have hit that key on my controller while scrolling through the long list of commands, and inadvertently assigned it to a command (I think it play-enabled chunk "Sequence 1", so nothing obvious happened in my single chunk project). I deleted the custom command and voila, all is now back to normal..
So keep both hands on the computer keyboard at all times when setting custom key commands! :lol:
Re: Custom key commands - a cautionary tale
This F# command has happened to so many people for so long that I hesitate to call it user error, rather possibly a bug. A suggestion has been made to save the project with the F# key command disabled as a template as a workaround.
Phil O
Post by Phil O »
Quite a few years back I recall having a keyboard player in the studio and having the same (or similar) problem. I can't remember if it was F#3 but I do remember it was an F#. I screwed around for a while and finally called MOTU. The person I spoke to immediately knew the problem and told me that a command was set to some F# by default. (I can't imagine why they would do that.) But, anyway, the quick fix was to uncheck Master Master in the commands window.
I never use MIDI event commands so I don't miss the functionality and I've just left it that way. So, it's not a bug. It's just IMHO a poor decision by MOTU. Like I said that was a while ago and I don't know if that has changed in recent versions of DP.
CharlzS
Post by CharlzS »
In older versions of DP some MIDI commands were included in the default set - mostly transport and activated by checking the MIDI Masters at the top of the list. The more recent DP default set doesn't have any defined. They come in handy sometimes but if you use them, I recommend setting the source along with the MIDI event. That way when using a different keyboard or device y0u don't get any surprises. Some cheap controllers (ie Korg Nanos) can be very handy at times. Some apps (Metagrid) make extensive use of MIDI commands.
Finger Drum Pads make great Custom Keys... you can put them outside of the normal 88 range.
I've got a Korg PadControl I use for finger drumming, with a couple of presets set up for my preferred drum layouts. My Arturia keyboard also has a set of pads I have preset for articulation control. Either could easily be used to trigger key commands.
https://rbohemia.com
I didn't look at everything, but I don't see any MIDI event assignments in my COMMANDS window.
Are COMMANDS saved with each individual project? If so, then MOTU can hardly be blamed for COMMAND assignments from old projects. That said, there perhaps should be a "best practices" step that people can take with old projects, new projects, and defaults/templates that has to do with making sure you don't get bitten by this particular "feature".
Tidwells@aol.com
Post by Tidwells@aol.com »
HOLY GUACAMOLE! I've been living with a "broken" F#2 key on my MIDI keyboard for several years. I just checked the DP Command window and sure enough, that note was assigned to "Master Sequence"?? I believe. I deleted it and now the note plays on my keyboard! AMAZING!
I don't use a template, I start with a new project for every song. Will I have to delete this command every time I start a new project? It was the only command in the Command window which was assigned to a MIDI event.
Doug
daniel.sneed
Post by daniel.sneed »
I've been caught by this one a few years ago. F# assigned to a sequence.
The cure is delete the MIDI command. Fast and easy.
But I can't remember what action, or actions chain, dit set that command in my computer.
Things may appear as bugs, while they are unexpected features.
crduval
Post by crduval »
Tidwells@aol.com wrote: Mon Jan 22, 2024 11:19 am HOLY GUACAMOLE! I've been living with a "broken" F#2 key on my MIDI keyboard for several years. I just checked the DP Command window and sure enough, that note was assigned to "Master Sequence"?? I believe. I deleted it and now the note plays on my keyboard! AMAZING!
Doug
That's great! I think the command list persists for all projects, so you should be good.
Chris
crduval
Post by crduval »
Phil O wrote: Mon Jan 22, 2024 6:09 am
Thinking back, I think this was actually what happened in my case. I had checked the "Master Master" box as I was playing around with the commands window. Based on others' comments, I think that F# command was already in there as a default, but only became active when "Master Master" was checked. So it wasn't a result of my left hand noodling around on the keyboard while I scrolled around with the right, as I originally thought.
JSmith1234567
Post by JSmith1234567 »
I actually eventually made a ever-updated list on my laptop of every MIDI controller # or note I've hijacked for some macro or key-command.
Also every key-combo, so I can quickly find unused ones.
Post by Rick Cornish »
Thanks for posting, crduval. I've run into similar issues myself. This is one to watch out for, for sure.
Though DP can export the COMMANDS, there's no option to view as a spreadsheet-- which would be helpful. Viewing it in TextEdit just shows a long string of gibberish.
It's way too big for one screen grab.
CharlzS
Post by CharlzS »
When you have the Commands window open you can use the File —> Print Window in the DP menu.
CharlzS wrote: Mon Jan 29, 2024 12:03 pm When you have the Commands window open you can use the File —> Print Window in the DP menu.
Ah, right. Thanks for the reminder. And you can print as PDF on Mac.
Just a note, it will only print what is "revealed" in the window. I manually clicked on every disclosure triangle for every category and it went from 3 pages to 20 pages.
Also, Mac doesn't appear to allow me to copy & paste the content in that PDF into a spreadsheet.
