DP11.3 Sequence Editor MIDI Note Visibility while editing note duration -FIXED DP11.32
Re: DP11.3 Sequence Editor MIDI Note Visibility while editing note duration
Or make your own theme. That’s the real feature, not the stock themes from MOTU. Or use one of those posted here. Rick Cornish did a really nice one that I use with a couple of tweaks.
I’m seeing this too, but only intermittently. I’m a MoTools theme user too. Haven’t investigated other themes to see if they do it. I’ll do so next time it crops up.
I also have an ongoing issue where my cursor tools often disappear. Between not being able to see the MIDI note I’m editing and not having cursor tools, I really am flying blind when both happen at once.
Beyond Black 2.3, DP 11.3 MIDI notes are outlines like they should be when you edit them. So in the best theme all is good.
