MIDI playback timing sloppiness help
Re: MIDI playback timing sloppiness help
Did you see my posts? What version of Kontakt 7 do you currently have installed and did you have Kontakt 7.6.1 installed at any point? Not sure just having a lot of Kontakt instances would necessarily cause that unless there might be an issue with Kontakt and it *might* because of having 7.6.1 installed at some point. This, as I said, doesn't sound like a DP issue.
Just noticed this post should have been in the Troubleshooting forum all along. Moved.
HCMarkus wrote: Sun Dec 10, 2023 7:06 am Tim, appreciate it if you'd create a signature with system info... that way, I won't have to keep scrolling thru this thread to fid that you are running an M2 Mini. Still don't know what OS version you are running.
Or how much RAM? I was just looking for that info too as he says he reduced the problem by eliminating several instances of Kontakt 7 from his template. I could see perhaps where having limited RAM might cause a problem like that? I still suspect that something might not be kosher after having Kontakt 7.6.1 installed for a while.
