Windows Set Digital Performer 10.13
Belushi
Post by Belushi »
Hello together,
I open and work with the safe window setup. After I have enlarged and edited tracks, I want to call up my old window Setup again. I can't do that. I still have my window what I edited before. Only when I close the song and then open this again, I can open the secured windows as I saved them. Is there a lock to save the windows settings?
What am I doing wrong?
Greetings, Denis
G4 1,6 GHz Dual MDD, OS X 10.3.9 Pro Tools 6.41 Mix +, G5 OS X 10.11.6, DP 10.13, Logic 9.18 & 10 ;Melodyne,EZdrummer,V.Guitarist-2,Raging Guitars,NI Komplete, Roland JV2080,S760,ATARI STE,...
Re: Windows Set Digital Performer 10.13
Not sure what a secure or safe window set it, but I assume you are talking about Window Sets.
If so, I hadn't notices this before. You're right -- invoking a saved Window Set does not set the track heights to their original values showing when the Window Set was saved.
Whether this is a bug or an overlooked design aspect, it should be fixed.
Belushi
Post by Belushi »
Hello,
thank you for the answer.
„ but I assume you are talking about Window Sets.
Yeah, that's exactly what I mean. I think the mistake has been since I worked with DP 9. Can anyone tell me if the mistake is still in DP 11 ?
Greetings, Denis
Belushi wrote: Sun Oct 29, 2023 2:51 pm Can anyone tell me if the mistake is still in DP 11 ?
Greetings, Denis
Yes, I tried this out on DP 11 and got the same result you reported.
You can Option Drag one track's vertical dimension in the Sequence Editor and all other visible tracks will conform to the same vertical size. This makes resetting pretty painless.
Belushi
Post by Belushi »
Hello HCMarkus
thanks for the tip. That helps me a little.
Unfortunately, the Window Sets makes no sense to me. It must already call up what I have saved.
Have a nice weekend, Denis
Belushi wrote: Sun Nov 05, 2023 5:05 am Hello HCMarkus
I'd suggest starting a Techlink with MOTU on this. Even if they don't have an answer, they may still be prompted to fix the issue.
