AVB Switch - There seem to be two models - which is the best/most up-to-date
CZFred
Post by CZFred »
Screenshot 2023-10-26 at 09.12.38.png (155.66 KiB) Viewed 2374 times
See the feft and right (ignore the middle) that the socket layout is different. Which is the up-to-date, best one? The one with 6 sockets all together, or the one that's 1-4-1?
Thanks, any info appreciated.
CZFred
Re: AVB Switch - There seem to be two models - which is the best/most up-to-date
motu.com is showing the AVB Switch as 5-ports
Screenshot 2023-10-26 at 10.51.33 AM.png (145.63 KiB) Viewed 2344 times
until you click on the link to see that it is now 6 ports.
Screenshot 2023-10-26 at 10.51.07 AM.png (683.89 KiB) Viewed 2344 times
Since the picture you're showing for 1–4–1 is used, I'll guess that the 6-port version is current.
Back in the day, Ethernet switches used to have an uplink port and a network port which explains the old picture. Nowadays, all ports on switches have full functionality.
CZFred
Post by CZFred »
Right, thanks.
So I guess, if you're always going to use one for ethernet there's no disadvantage buying the older model. Daft that MOTU's own site still shows both models as if they're the same one. But anyhow - thanks again!
