Just installed AT Pro X and I cannot turn any knobs! Ventura and DP 11.23
Initially was using AU version
Think I got the VST version going but the same problem.
Help!
AutoTune Help
Re: AutoTune Help
First, are you running the latest Codemeter Runtime (license manager used by Antares)? You won’t find it on the Antares website. I don’t have the link here but I posted it a week or two ago. Do a search and you should find that. Download and run the installer to update. I believe there is a Ventura bug fix in it.
Finding it on the WIBU site is difficult but the link I provided takes one to the download page for Mac and Windows.
Antares hasn’t supported VST in years. AU and VST3, yes.
Re: AutoTune Help
Will try this CodeMeter suggestion ASAP. (Thanks Mike H!)
I should have added this detail:
I installed AutoTune on the "work" computer and it seemed to function properly.
As per the license agreement, I sought to install it on the "home" computer.
The install went as expected with no issues, but on the 2nd "home" machine, I am unable to turn any knobs.
It also will not pass audio unless I bypass (the only parameter I can manipulate)
I am doing all of this using the latest AutoTune Central
Obviously, Antares ought to be the ones to help me out with this, but I'm waiting to hear from them.
Re: AutoTune Help
Uninstalled CodeMeter and installed the most current version.
Unfortunately, that did not solve the problem.
Re: AutoTune Help
Following up here because this support community is so powerful and appreciated:
I installed AutoTune Pro X on two virtually identical iMac systems without noticing that one was still back on Monterey while the second was on Ventura. The second install did not function properly, but AutoTune Central said that two activations were in use.
Mike Halloran offered the CodeMeter suggestion above. What did not occur to me at the time is that the issue Mike brought to light is very likely the reason that the install worked perfectly on the Monterey machine and not the Ventura machine.
Unfortunately, installing the latest version of CodeMeter alone could not fix the problem becuase at this stage, the flawed activation was already in place. What was additionally needed was a refresh of the available AT activations so that the "broken" machine could be properly activated. Once Antares provided this, the fix was easy.
Could be way off, but the bottom line is that it all works now!
