Slate Digital Audio VSX?
Tried to load the VSX headphones AU into D.P. 10.13.
Under Setup / Audio Systems, I only have MOTU Audio Systems and MIDI only
Anyhow I since loading in the VSX AU, D.P. is no longer seeing my audio interface or any of my plug ins. Crazy??
I have a support ticket in for Slate Audio about this. Waiting for a reply
- audio driver not loaded.png (267.59 KiB) Viewed 548 times
- Screen Shot 2023-02-20 at 2.29.41 PM.png (196.23 KiB) Viewed 548 times
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
Re: Slate Digital Audio VSX?
I've been looking at these. Not going to pull the trigger till resolved.
I'm not seeing most of my Slate plug-ins, Not sure if it's Ventura or what? I may have to break down and read the manual.
I bought Slate VSX Essentials and then upgraded to Platinum. Not having any issues here on Monterey. I’m using the AU on my master bus. It has definitely helped my mixes. Especially judging low end.
Well I posted this to see if anyone else was having problems loading this plug in. I also have Logic and opened that up to find that the plug in loaded fine on that platform. So it seems to be just a D.P. issue maybe.
Hey James, I was wondering what your reasoning was for upgrading to Platinum. Did you feel you needed more simulated environments? Also I'm assuming you're using D.P. 11??
I just got hooked on hearing the different rooms and because I had purchased a number of the add-on rooms it was no brainer when Slate had an offer recently to upgrade and get a refund on rooms purchase separately. You’ll find you like certain room more than others.scooter wrote:Hey James, I was wondering what your reasoning was for upgrading to Platinum. Did you feel you needed more simulated environments? Also I'm assuming you're using D.P. 11??
Thanks. Well I'm finally up and going. I upgraded to D.P. 11 and that solved that one issue.I just got hooked on hearing the different rooms and because I had purchased a number of the add-on rooms it was no brainer when Slate had an offer recently to upgrade and get a refund on rooms purchase separately. You’ll find you like certain room more than others.
My issue isn't the low end. I'll share how I deal with that in a new thread. Instead, there's a midrange band that gives me grief.
Here's hoping that VSX can help me deal with that. I pulled the trigger on Platinum today.
I’m currently still using my Event ASP8s and then I have a set of JBL 4410s that I like using for tracking just because it sounds big. I use ARC3 with them, but I’ve changed things around recently and need to make new profiles.mikehalloran wrote:My issue isn't the low end. I'll share how I deal with that in a new thread. Instead, there's a midrange band that gives me grief.
With the 10” woofers it seems like I’d get plenty of low end but when I used VSX I noticed I had too much in my mixes and VSX helped me with that. What bothers me a little is that there are a couple of preset kits in Superior Drummer that seem to have too much low end on the kick drum. I wonder how this could happen, because you assume these presets by famous engineers would be dialed in just great? I dunno.
I’m anxious to hear your thoughts when you get it. They recommend listening to some reference tracks you’re familiar with to get used to it. I never really experienced the *full* illusion that you’re in a room with the speakers, but it does feel more like things are coming from in front and that it’s a very helpful supplement to monitors.Here's hoping that VSX can help me deal with that. I pulled the trigger on Platinum today.
I do wish the headphones were the type that would mute themselves when you take them off your head. I’m monitoring via the headphone jack on the front of my 828es which doesn’t have a mute function that I can tell. When I take them off to listen through monitors I have to either unplug them or spin the headphone volume knob A LOT to turn them all the way down.
