Convert to mono
Convert to mono
Hi All,
I have been using the Chris Lord-Alge vocal plug on voice overs of late. It's a stereo plug, so when I insert it anywhere it converts the track, or aux, from mono to stereo, which in turn results in a stereo soundbite when mixed.
I'm only using it for compression basically, so I dont need a stereo mix. Is there any way, when exporting a sound bite, to convert it to mono, or to export just one side only? (Since the left and right sides are identical I dont need both.)
Thanks in advance,
Gavin
Thanks in advance,
Gavin
Mac mini M1, 14.7, 16gigs RAM, 828 mk3 Hybrid, DP 11.31, Various VIs
Re: Convert to mono
One option is bounce the track to mono.
Re: Convert to mono
Or you can convert the file from Interleaved to Non-Interleaved in Soundbites window, then drag to desktop. You will now have two mono files with L and R appendages. Re-name either one to omit the L or R and you have a mono file.
Re: Convert to mono
I use both methods, depending…
This changes the track's level even if you set the Bounce to -3.5dB. Sometimes, I want this.
This does not change the track's level and is faster.
- mhschmieder
Re: Convert to mono
Wow, I hadn't thought of HC's trick, and I like how it doesn't change the level, as this can be a problem in carefully balanced mixes where it's just one track vs. the final mix that is being converted to mono. Especially given different pan law treatment, it can be a royal pain to rebalance the tracks afterwards.
Given that's one's settings may be determined by confidence in mix levels during the unfortunately stereo initial rendering, would one need to do a mono aux send and have that be the only contributor to the Master Fader's output channels, leaving the track's main post-compression outputs to internal routing only?
I seem to recall that you can also drag where the pre-vs-post point is in a stack of inserts. It's been eons since I've done that, but I've never seen DP remove a feature once it's in place, so you might even be able to insert Trim to get it back to mono and even have that be part of your confident mix and balance monitoring while you are choosing the plug-in's settings.
Re: Convert to mono
I'm not exactly sure what this means, but I'll give it a shot and report back for further instructions when I screw it up. Haha.
Re: Convert to mono
Thanks HC. Your method is easy and fast, but......
That gives me .wav files, of course. I forgot to mention that I'm usually converting to mp3 as I export. Any easy way to wind up with a mono mp3?
Gavin
Gavin
Re: Convert to mono
DP is the slowest way I know to create an mp3. If you use a 3rd party converter, it will save a ton of time. AppleMusic/iTunes is free but there are other apps that take less time including DSP-Q.
I use TwistedWave which, like DSP-Q, can take a few hours of mixed format files, convert all to mp3 and put back into their own folders or a new destination in a few seconds.
Re: Convert to mono
I drop the .wav file into Apple's Music, which I have set to convert to high quality MP3.
Re: Convert to mono
Ok, so the conversion to mp3 has to happen after? No way to export a stereo sound bite as a mono mp3, straight out of DP? I know, asking way too much, right?
I’m only converting short files so it doesn’t really matter to me that DP is slow in that department.
Re: Convert to mono
There might be, I've just never looked. When I drop a .wav onto Apple Music, I convert to MP3 and discard the .wav copy once the conversion. is done. That way, I don't add bloat, yet still have a copy of the MP3s I've created in one place for reference or other uses.
Re: Convert to mono
This seems to be a two stage process, correct? Although in "Music>Preferences>Files>Import Settings" I have it set to "Import Using: MP3 Encoder" it's not happening. I drag the file into the library, but it's still a .wav file. I have to select it and then go File>Convert>Create MP3 Version. Do I have that right?HCMarkus wrote: ↑Thu Jan 12, 2023 8:38 amThere might be, I've just never looked. When I drop a .wav onto Apple Music, I convert to MP3 and discard the .wav copy once the conversion. is done. That way, I don't add bloat, yet still have a copy of the MP3s I've created in one place for reference or other uses.
Seems like it's supposed to convert it as it imports it, but it's not doing it.
Re: Convert to mono
I see it as you are seeing it... two-steps, yes.gavspen wrote: ↑Thu Jan 12, 2023 9:26 amThis seems to be a two stage process, correct? Although in "Music>Preferences>Files>Import Settings" I have it set to "Import Using: MP3 Encoder" it's not happening. I drag the file into the library, but it's still a .wav file. I have to select it and then go File>Convert>Create MP3 Version. Do I have that right?HCMarkus wrote: ↑Thu Jan 12, 2023 8:38 amThere might be, I've just never looked. When I drop a .wav onto Apple Music, I convert to MP3 and discard the .wav copy once the conversion. is done. That way, I don't add bloat, yet still have a copy of the MP3s I've created in one place for reference or other uses.
Re: Convert to mono
So not working as advertised then?
