FEATURE REQUESTS
FEATURE REQUESTS
Hi.
i have some useful feature request for Motu DP.
1. "WARP GRID" ( a tool for move grid to a particular position.It has already in Cubase)
2. Object FX (Object-soundbite Based fx and Aux send.It has already in Magix Samplitude)
3. Soundbite Based Automation (Draw automation upon each soundbite)
4. Monitor Control (useful for headphone and monitor control profile plugins like SONARWORKS,WAVES NX MIXROOMS)
How can i send these suggestions to the motu DP developers for future updates..?
Re: FEATURE REQUESTS
suggestions@motu.com
Not sure what warp grid is, but look up “Adjust Beats” in manual. It might be similar.
WARP GRID
it's a feature ... (tool) can move Grid or beat to a desired position.
Hope you check warp grid in cubase.
https://youtu.be/z_JDVUH_kCM
WARP GRID is too useful in background scoring ......
we can move ...drag a bar to a desired video position to the exact synchronisation
That's very cool.... good idea to write to MOTU about it. This is a board about DP... not a Cubase promotion board. Nothing against Cubase... I own it also. MOTU doesn't monitor this board too much, so again best writing to them at the address I mentioned. Maybe send them the link to this topic if you don't want to compose an email restating the issue.
- bralston
If one uses the "find tempo" tool that ONLY DP has to find the best tempo to hit your markers that you imported from your spotting session...one should not have to "warp the grid" or what DP calls "Adjust beats" to hit things.
set markers
assign importance
find tempo (setting a rough tempo window to search)
search by the .25 beat.
change sequence to that found tempo. It will tell you how accurately you hit your beats to the frame.
then...begin to write the cue.
Or
If you still want to have a tempo track that changes a lot...use DP's "Adjust beats." It is the same thing.
set markers
assign importance
Or
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Brian Ralston
Give an option to Polar to work like a pedal looper....
MacPro 5.1 6-core 3.33GHz 16GB RAM.
Motu 2408MKI PCIe 424, with Focusrite octopre
Alphatrack.
DP7.24, SD2, Omnisphere 1, Komplete 7,Ethno.1.0.1,Styllus RMX 1.8
Alphatrack.
You should be able to set this up with a Bheringer FCB1010. That company usually makes cheap knock offs, but the FCB1010 is great, you can assign all of Polars parameters to the footpedals and hopefully have what you need.
Region Edit/Split Note/Custom Stutter Curve
Select a long note, choose split note which will break it in to a series of faster notes--- but also have a curve so that it can accelerate or decelerate those notes across the duration.
It would be AMAZING to be able to
- Color Code Markers!!
- Have Fonts, Bold, Italic, and Colors available in Project Notes!!
Please
Please
- rixax@vex.net
I use a stream deck and BOME MIDI translator. In BOME, I record mouse movements and clicks to select from my list of saved times. Then I add a key command to the sequence of those movements and assign them to the stream deck. So I have about 25 meters that I can select, also select new pass on the stream deck. Then I can create phasing loops. I also assign a button on the stream deck to stop recording so I can solo over the loops.Michael Canavan wrote: ↑Thu Feb 02, 2023 7:26 amYou should be able to set this up with a Bheringer FCB1010. That company usually makes cheap knock offs, but the FCB1010 is great, you can assign all of Polars parameters to the footpedals and hopefully have what you need.
Two things really bug me and I have been asking MOTU to fix this for years. First, add 'saved times' to the commands window. Second, POLAR ins and outs disappear when you switch projects. They stay between sequences but not projects.
