Mac randomly shuts down with UltraLite MK4 connected after installing Pro Audio driver v91429
thanatopsis
Post by thanatopsis »
TL;DR: Has anybody else had random Mac shutdowns (with cause -3 "Multiple temperature sensors exceeded the defined limit" since installing MOTU Pro Audio v91429 from June 21, 2022?
I've had my Mac Pro 2019 and UltraLite MK4 a couple years. Beside the horrible lag problem that made it impossible to monitor live analog inputs from the MK4, it worked OK. I'm currently running macOS 11.6.
Last month I saw MOTU Audio driver version 91429 was released in June, which was supposed to fix the lag problem. It did! But every since then my Mac Pro has shut down randomly every few hours with code -3 "Multiple temperature sensors exceeded the defined limit." I cleaned out the computer and fans as I do every 3-6 months. I ran Apple's diagnostic. It said everything was fine. TG Pro has had no abnormal fans reading this whole time.
I tried installing macOS 12 on an external drive. The Mac worked fine again. A few days later I installed my favorite virtual synths, DP11 and the audio driver version 91429. Again the Mac started shutting down without warning every few hours, even when just idle.
I saw there was an update to macOS 11, so I went back to that version and installed the update. It still shut down randomly.
Last week we had a power outage that lasted 6 hours. When the power came back on, my Mac worked fine. it worked fine for days. No more random shutdowns. I was mostly using it for Web pages and listening to music with my Airpods. Then i realized when the power went out the UltraLite MK4 shut down and I never turned it back on. I turned it back on and had 2 random shutdowns within 5 hours, just viewing Web pages. The UltraLite has been off the last few days and I haven't had anymore random shutdowns with code -3.
Has anybody else experienced anything like this? I have a ticket in with MOTU.
Re: Mac randomly shuts down with UltraLite MK4 connected after installing Pro Audio driver v91429
You're doing everything right but something is getting in the way.
I'll assume that you've tried resetting the NVRAM and SMC. This is a bit of a Hail Mary but I would reset the Launch Services to Default to eliminate that as a cause.
Reset Launch Services
1. Open Terminal and run these commands:
2. /System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -kill -seed -lint -r -f -v -dump -domain local -domain system -domain user -domain network <Enter or Return key>
3. killall Dock <Enter or Return key>
4. sudo mdutil -E / <Enter or Return key> (enter Admin password when prompted, then <Enter or Return key>)
5. Restart your Mac
Lots of things can be interfering. If the above doesn't do it, you have to find the culprit. The Activity Monitor, diligence and patience are normally your best friends. Suspect anything from Corel except Toast — there's a background process that causes lags and the only way to eliminate it is to disable SIP and purge everything with Corel in the name. They've been informed and have done nothing.
When diagnosing, Find Any File.app can locate things that elude Finder/Find. It's shareware https://apps.tempel.org/FindAnyFile/ so you can try for free. If you buy it from the App Store, update notifications are automatic.
I recently had a nasty conflict with an older CodeMeter Runtime (Antares, NI and others use this). I found it by going through every App, Extension and License to make certain that I was running the latest and greatest. Fortunately, AutoTune was in the As so it didn't take as long to find as it might.
mikehalloran wrote: Thu Aug 04, 2022 10:09 amWhen diagnosing, Find Any File.app can locate things that elude Finder/Find. It's shareware https://apps.tempel.org/FindAnyFile/ so you can try for free. If you buy it from the App Store, update notifications are automatic.
I have to just add quickly that FindAnyFile is absolutely indispensable for me. I wish Apple's built-in "Find" worked like this. I use this almost exclusively now.
Oh... I just checked the site and it's still only $6!! Just get it. It's terrific!
thanatopsis
mikehalloran wrote: Thu Aug 04, 2022 10:09 am You're doing everything right but something is getting in the way.
Yes, I did reset the NVRAM and SMC. I should have mentioned that. I have not tried Launch Services. I'll try that tonight. Thanks.
So far MOTU has just asked me to run Apple's diagnostic, which I did previously. I believe I told them that. But I'll try that again and get back to them.
I need to look at the crash report better to, and maybe compare a few of them, which I haven't done yet. I've send some to Apple, but not to MOTU. Maybe they can make more sense out of it.
Thanks again!
James Steele wrote: Thu Aug 04, 2022 11:51 am
As the description says: "A popular alternative to FAF is EasyFind by DEVONtechnologies. It offers a different search interface and has a single-window user interface which you might prefer. And it's free." I've use both and would agree. Also agree that the Find command in macOS is pretty useless.
thanatopsis
mikehalloran wrote: Thu Aug 04, 2022 10:09 am Reset Launch Services
5. Restart your Mac
I rebuilt launch services. I'm not going to call it fixed yet, but I've had my Mac on with the UltraLite plugged in for over 8 hours now. I don't think I made it more than 5 or 6 hours without the Mac shutting down before.
I would have never thought to do that since it shut off even with a fresh install of Monterey on a new drive, plus the MOTU software.
But I've been using DP 11 and other processor-intensive tasks and have had no problems. It used to die just sitting idle for a few hours.
I'll give it a few days, but I hope it is fixed.
Thanks for the help!
thanatopsis
bayswater wrote: Thu Aug 04, 2022 7:16 pm
Yeah, I have FindAnyFIle and EasyFind. Spotlight has is purposes, but I don't use it nearly as much as these other search programs.
thanatopsis wrote:Yeah, I have FindAnyFIle and EasyFind. Spotlight has is purposes, but I don't use it nearly as much as these other search programs.
I’m going to have to try EasyFind. I was unaware it.
thanatopsis wrote: Fri Aug 05, 2022 4:44 am
You're welcome. You'll know for certain in a few days.
avbkiller
Post by avbkiller »
Hallo,
i guess we got the same problems when using the "UltraLite" soundcard with macOS on the M1 with the latest drivers.
I did read your post and i guess that you will report back that the problem still exists even after the advise from other users here?.
If so, please check your latest Crash report after the kernel panic and look and see if the "USB driver" is mentioned? You'll find it some lines down in your report. Please check my post too, maybe we got the same problem with the drivers?
viewtopic.php?t=72465
kind regards
thanatopsis
avbkiller wrote: Sat Aug 06, 2022 3:41 am If so, please check your latest Crash report after the kernel panic and look and see if the "USB driver" is mentioned? You'll find it some lines down in your report. Please check my post too, maybe we got the same problem with the drivers?
My problem wasn't fixed.
My computer stayed on all night, longer than ever before since the problem began, but then I turned it off before leaving. When I came back and turned it on, it shut down within an hour. I noticed some of the crash reports say MOTU Driver (they DO include mention of USB Driver) and other crash reports are MDS (Spotlight searching).
I disabled Spotlight searching. Instead of using a command like "Sudo mdutli – a -i off" I just dragged all my drives to the "Do not index" area of Spotlight.
It hasn't been 24 hours yet, but no more crashing so far. Not really a solution, since I use Spotlight even though I have other apps like EasyFind. If the Mac doesn't crash for a few days, I'm going to try enabling Spotlight search for a drive at a time and see how it goes. It could be the MOTU crashes and the MDS crashes are unrelated, but I have far more MOTU crashes than MDS and the computer has been on for at least 18 hours without crashing.
I don't know how to add one of those scrolling text boxes, so I'll just put my whole crash report in a reply.
thanatopsis
Here's one of the MOTU driver crash reports.
Process: com.motu.driver.pro.audio.dext [515]
Path: /Library/SystemExtensions/*/com.motu.driver.pro.audio.dext
Identifier: com.motu.driver.pro.audio.dext
Version: 2.0.0 91429 (2.0.0 91429)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
Responsible: com.motu.driver.pro.audio.dext [515]
User ID: 270
Date/Time: 2022-08-06 21:40:10.059 -0800
OS Version: macOS 11.6.8 (20G730)
Report Version: 12
Bridge OS Version: 6.6 (19P6064)
Anonymous UUID: 03705F8A-3D38-16A4-F662-4285A352D313
Time Awake Since Boot: 1000 seconds
System Integrity Protection: enabled
Crashed Thread: 1 Dispatch queue: IOCompletion_DispatchQueue
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
dyld2 mode
abort() called
Thread 0:
0 libsystem_kernel.dylib 0x00000001089804c2 __sigsuspend_nocancel + 10
1 libdispatch.dylib 0x00000001087ccdd1 _dispatch_sigsuspend + 36
2 libdispatch.dylib 0x00000001087ccdad _dispatch_sig_thread + 55
Thread 1 Crashed:: Dispatch queue: IOCompletion_DispatchQueue
0 libsystem_kernel.dylib 0x000000010897ffd6 __pthread_kill + 10
1 libsystem_pthread.dylib 0x0000000108aae28e pthread_kill + 177
2 libsystem_c.dylib 0x000000010890d635 abort + 125
3 com.apple.DriverKit 0x0000000108593e75 __assert_rtn + 102
4 com.apple.DriverKit 0x0000000108594bd2 OSAction::GetReference() (.cold.1) + 35
5 com.apple.DriverKit 0x000000010857dde0 OSAction::GetReference() + 24
6 com.motu.driver.pro.audio.dext 0x000000010853e2f0 com_motu_driver_proaudio_device::USBIsocIOStream_InIsocCompletionProc_Action_Impl(OSAction*, int) + 16
7 com.apple.USBDriverKit 0x00000001085ece23 IOUSBHostPipe::CompleteAsyncIsochIO_Invoke(IORPC, OSMetaClassBase*, void (*)(OSMetaClassBase*, OSAction*, int), OSMetaClass const*) + 97
8 com.apple.DriverKit 0x000000010857aa7b invocation function for block in OSMetaClassBase::Invoke(IORPC) + 117
9 com.apple.DriverKit 0x000000010857a6e8 OSMetaClassBase::Invoke(IORPC) + 782
10 com.apple.DriverKit 0x000000010857af69 Server(void*, mach_msg_header_t*, mach_msg_header_t*) + 596
11 com.apple.DriverKit 0x000000010857c3b3 uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int) + 149
12 libdispatch.dylib 0x00000001087d24b4 _dispatch_mach_msg_invoke + 444
13 libdispatch.dylib 0x00000001087c1dcb _dispatch_lane_serial_drain + 263
14 libdispatch.dylib 0x00000001087d2ff6 _dispatch_mach_invoke + 484
15 libdispatch.dylib 0x00000001087c1dcb _dispatch_lane_serial_drain + 263
16 libdispatch.dylib 0x00000001087c2a18 _dispatch_lane_invoke + 417
17 libdispatch.dylib 0x00000001087c3c49 _dispatch_workloop_invoke + 1784
18 libdispatch.dylib 0x00000001087cc4fb _dispatch_workloop_worker_thread + 811
19 libsystem_pthread.dylib 0x0000000108aaee65 _pthread_wqthread + 314
20 libsystem_pthread.dylib 0x0000000108ab4c8b start_wqthread + 15
Thread 2:
0 libsystem_pthread.dylib 0x0000000108ab4c7c start_wqthread + 0
Thread 3:: Dispatch queue: com_motu_driver_proaudio_userClient-Default
0 libsystem_kernel.dylib 0x00000001089810a2 kevent_id + 10
1 libdispatch.dylib 0x00000001087d7ef7 _dispatch_kq_poll + 163
2 libdispatch.dylib 0x00000001087d89f7 _dispatch_event_loop_wait_for_ownership + 503
3 libdispatch.dylib 0x00000001087c90ff __DISPATCH_WAIT_FOR_QUEUE__ + 270
4 libdispatch.dylib 0x00000001087c8d62 _dispatch_sync_f_slow + 170
5 com.apple.DriverKit 0x000000010857c67b IODispatchQueue::DispatchSync_f(void*, void (*)(void*)) + 145
6 com.motu.driver.pro.audio.dext 0x000000010853af41 com_motu_driver_proaudio_userClient::Stop_Impl(IOService*) + 145
7 com.apple.DriverKit 0x000000010858e5b6 IOService::Stop_Invoke(IORPC, OSMetaClassBase*, int (*)(OSMetaClassBase*, IOService*)) + 86
10 com.apple.DriverKit 0x000000010858ea00 IOService::Stop(IOService*, int (*)(OSMetaClassBase*, IORPC)) + 234
11 com.apple.DriverKit 0x000000010858e3d3 IOService::_Dispatch(IOService*, IORPC) + 305
12 com.apple.DriverKit 0x000000010857aa7b invocation function for block in OSMetaClassBase::Invoke(IORPC) + 117
13 com.apple.DriverKit 0x000000010857a6e8 OSMetaClassBase::Invoke(IORPC) + 782
14 com.apple.DriverKit 0x000000010857af69 Server(void*, mach_msg_header_t*, mach_msg_header_t*) + 596
15 com.apple.DriverKit 0x000000010857c3b3 uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int) + 149
16 libdispatch.dylib 0x00000001087d24b4 _dispatch_mach_msg_invoke + 444
17 libdispatch.dylib 0x00000001087c1dcb _dispatch_lane_serial_drain + 263
18 libdispatch.dylib 0x00000001087d2ff6 _dispatch_mach_invoke + 484
19 libdispatch.dylib 0x00000001087c1dcb _dispatch_lane_serial_drain + 263
20 libdispatch.dylib 0x00000001087c2a18 _dispatch_lane_invoke + 417
21 libdispatch.dylib 0x00000001087c3c49 _dispatch_workloop_invoke + 1784
22 libdispatch.dylib 0x00000001087cc4fb _dispatch_workloop_worker_thread + 811
23 libsystem_pthread.dylib 0x0000000108aaee65 _pthread_wqthread + 314
24 libsystem_pthread.dylib 0x0000000108ab4c8b start_wqthread + 15
Thread 4:: Dispatch queue: com_motu_driver_proaudio_userClient-Default
Thread 1 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000193 rcx: 0x000070000b36fed8 rdx: 0x0000000000000000
rdi: 0x0000000000000193 rsi: 0x0000000000000006 rbp: 0x000070000b36ff00 rsp: 0x000070000b36fed8
r8: 0x0000000000000010 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000206
r12: 0x000070000b3700c0 r13: 0x0000600002b60058 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: 0x000000010897ffd6 rfl: 0x0000000000000206 cr2: 0x0000000108594baf
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Thread 1 instruction stream not available.
Thread 1 last branch register state not available.
Binary Images:
0x108533000 - 0x108552fff +com.motu.driver.pro.audio.dext (2.0.0 91429 - 2.0.0 91429) <0EE82E3B-9BCB-3258-9E0B-DB8DD2631BE6> /Library/SystemExtensions/*/com.motu.driver.pro.audio.dext
0x108578000 - 0x1085a3fff com.apple.DriverKit (1.0 - ???) <1CDA50BF-F530-3A98-85CA-D234D2387966> /System/DriverKit/System/Library/Frameworks/DriverKit.framework/DriverKit
0x1085e7000 - 0x1085f2fff com.apple.USBDriverKit (1.0 - 1) <92309B42-9E42-3FE3-91F4-0F521E7248B5> /System/DriverKit/System/Library/Frameworks/USBDriverKit.framework/USBDriverKit
0x108609000 - 0x10860cfff com.apple.PCIDriverKit (1.0 - 1) <347DC639-FE74-348E-8677-84BD0E8B01E0> /System/DriverKit/System/Library/Frameworks/PCIDriverKit.framework/PCIDriverKit
0x108620000 - 0x108647fff com.apple.HIDDriverKit (1.0 - 1) <9B344ECB-31CF-3526-8149-8A8AF919E4D6> /System/DriverKit/System/Library/Frameworks/HIDDriverKit.framework/HIDDriverKit
0x108673000 - 0x108686fff libc++.dylib (905.6) <FFA3484A-2609-3C03-9D99-FEDC29657F4F> /System/DriverKit/usr/lib/libc++.dylib
0x1086a8000 - 0x1086abfff libSystem.dylib (1292.120.1) <15BFE9CD-A385-3678-A1B2-0FB441E84710> /System/DriverKit/usr/lib/libSystem.dylib
0x1086bc000 - 0x1086c3fff libcompiler_rt.dylib (102.2) <54E709C1-998F-3996-9D2B-038C3C6C764F> /System/DriverKit/usr/lib/system/libcompiler_rt.dylib
0x1086dd000 - 0x10878cfff libcorecrypto.dylib (1000.140.4) <BC0B7209-7A05-3131-90D5-AC61E8CD2507> /System/DriverKit/usr/lib/system/libcorecrypto.dylib
0x1087b7000 - 0x1087fefff libdispatch.dylib (1271.120.2) <BBE30F5B-3FE4-3C69-ADD3-81C63EA0D8BA> /System/DriverKit/usr/lib/system/libdispatch.dylib
0x10883b000 - 0x108852fff libdyld.dylib (852.2) <205AD49A-DABF-302E-B7BC-68995FC7F922> /System/DriverKit/usr/lib/system/libdyld.dylib
0x108876000 - 0x108879fff libmacho.dylib (980) <7C95822C-72C5-3A40-976D-D2FEF9A7CB2F> /System/DriverKit/usr/lib/system/libmacho.dylib
0x10888c000 - 0x10888ffff libsystem_blocks.dylib (79) <90FABE3A-64E3-3C85-87E1-33EF53A0EDE3> /System/DriverKit/usr/lib/system/libsystem_blocks.dylib
0x10889f000 - 0x108926fff libsystem_c.dylib (1439.141.1) <0C74116F-55C4-35C5-A21E-DEA0CA80BC6C> /System/DriverKit/usr/lib/system/libsystem_c.dylib
0x10895d000 - 0x108990fff libsystem_kernel.dylib (7195.141.32) <A57019EE-3B3E-3431-90CA-F748D2055ABC> /System/DriverKit/usr/lib/system/libsystem_kernel.dylib
0x1089bb000 - 0x108a0efff libsystem_m.dylib (3186.100.3) <941A5C16-A66C-3C85-AD4F-59F4111F45CF> /System/DriverKit/usr/lib/system/libsystem_m.dylib
0x108a2c000 - 0x108a5bfff libsystem_malloc.dylib (317.140.5) <4218B21B-8AF3-3219-9E11-52250A94AB86> /System/DriverKit/usr/lib/system/libsystem_malloc.dylib
0x108a81000 - 0x108a8cfff libsystem_platform.dylib (254.80.2) <FB5382D8-0239-3F9C-A66E-33D13D32B44A> /System/DriverKit/usr/lib/system/libsystem_platform.dylib
0x108aa9000 - 0x108ab8fff libsystem_pthread.dylib (454.120.2) <F93E6B37-EE76-3195-A2B3-16D69C7FA4C9> /System/DriverKit/usr/lib/system/libsystem_pthread.dylib
0x108ad7000 - 0x108adefff libsystem_trace.dylib (1277.120.1) <B9FF942A-CB9A-398D-8905-F76051097497> /System/DriverKit/usr/lib/system/libsystem_trace.dylib
0x108af1000 - 0x108b0cfff libc++abi.dylib (905.6) <850CABB5-4CC8-34B8-8903-6FB44FF678BC> /System/DriverKit/usr/lib/libc++abi.dylib
0x10d98a000 - 0x10da25fff dyld (852.2) <E20C43E3-CEB9-397A-9056-11A6A8D3F86E> /usr/lib/dyld
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=5480K resident=0K(0%) swapped_out_or_unallocated=5480K(100%)
Writable regions: Total=651.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=651.4M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Kernel Alloc Once 8K 1
MALLOC 264.2M 47
MALLOC guard page 24K 4
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
STACK GUARD 20K 5
Stack 2608K 6
Stack Guard 64.0M 2
VM_ALLOCATE 8K 2
__DATA 656K 24
__DATA_CONST 432K 22
__DATA_DIRTY 32K 2
__LINKEDIT 1888K 44
__TEXT 3936K 22
TOTAL 721.6M 182
TOTAL, minus reserved VM space 337.6M 182
Logical CPU: 0
Trap Number: 133
Do you have any Microsoft Office installed? If so, what version and build? I have never seen this in a crash report without Office being installed.
Also from your crash report:
Huh?
MOTU is showing this driver for your OS:
MOTU Pro Audio Installer
Version: 80789
Release Date: July 30, 2019
Supported Platforms
macOS 10.14, macOS 10.13, macOS 10.12, Mac OS X 10.11
What happens if you install that instead of this that does not include 10.11.x?
Version: 91429
Release Date: June 21, 2022
Supported Platforms
macOS 12, macOS 11
thanatopsis
mikehalloran wrote: Mon Aug 08, 2022 5:17 pm Do you have any Microsoft Office installed? If so, what version and build? I have never seen this in a crash report without Office being installed.
Huh?
Version: 80789
Supported Platforms
Version: 91429
Supported Platforms
macOS 12, macOS 11
I do have Microsoft Office installed. Version 16.16.27 (201012) is what Excel says. I don't use the other apps.
I'm not sure why I should use MOTU Pro Audio driver version 80789. Isn't that really old? I have macOS 11 Big Sur, not 10.11.x. The pervious MOTU drives all worked fine with the UltraLite, except there was always such lag that I could never use the inputs while monitoring them. 91429 got rid of the lag, but that's when my computer started shutting down.
I re-installed Monterey on an external drive and it hasn't crashed all week like it did the first time I tried doing that. I am going through the painful process of installing and registering everything again as I need it, as I don't want to risk Migration Assistant adding something that makes it crash again. So far everything still works. I still wish I knew what the problem was though.
I need new glasses. You have the right driver.
As drastic as that sounds, sometimes, a clean install is the best way. When I had similar problems a few months ago, I went through everything bringing it up to date and found my two big problems. A clean install would have fixed the CodeMeter issue as I would’ve downloaded the latest runtime.
I would still have had the Corel issue since I’d have reinstalled it. Fortunately, Apple’s Activity Monitor allowed me to find the problem and Find Any File allowed me to locate all the related files and remove it completely.
