DP 11 doesn't record (RESOLVED)
Hello Motufriends,
im working withe the newest version of dp11 and an ultraliteMk3-hybrid.
Since some times DP doesn't record with the analog inputs from my Mk3.
The Mic-Signal is hearable on my monitors, but in DP - it just records silence.
My Hardware-Settings seem to be ok.
When i try to record in Logic Pro, everything works ok, so it can't be a problem with the USB-Chip or -connection.
Any ideas what happens here?
Thanks a lot in advance, Marc
Re: DP 11 doesn't record
Make sure that your unit is set as input/output. With DP 11.1, Follow System Audio Settings defaults to On. Uncheck that box and see if that fixes you up. You'll see that I leave it unchecked.
- Screen Shot 2022-07-21 at 6.03.17 PM.png (102.17 KiB) Viewed 5962 times
Also- set microphone permissions to “on” for DP!
and all versions of DP over MacOS High Sierra and later. It’s a MacOS, not a DP thing.
Forgot about that. Thanks for catching.
You bet, I recently reinstalled DP 11 on my new Mac Studio Ultra, and I did not enable microphone permissions during the install.
I tried to record through my Apollo a few days later, and it would not let me.
After a few stumped moments I realized that I did not grant input permissions on the microphone, which apparently applies to any audio input device! .
You can adjust that setting on:
Preferences/security and privacy/privacy/microphone
By the way, I’m selling my UA OCTO 8 PCIe accelerator card and my Titan Ridge PCIe flashed TB3 card. In case anyone is interested.
Oh and my MacPro 5.1 and Apple Cinema Display 30” as well!
Is there a classified section here on MOTUnation?
Greg
Greg
Nope... and never will be. I don't want to get caught in the middle if a deal goes south.
That said, you mentioned your selling it in your post and if someone wants to PM you... well I guess that works. Thanks for offering it to me first, but I'm gonna just hang tight until I can pop for a Mac Studio in a couple months. I'll probably go with the M1 Max version, however.
Got it, thanks james
Just a follow up on this microphone permission thing: While I was migrating to a Mac Studio with Monterey 12.4, the first time I ran DP after setup I got a popup window asking if I wanted to allow Microphone permission, much to my surprise, since I have been keeping this issue in the back of my mind for a while. So yes, there is some kind of fail-safe along the way, but it is unfortunate that many people don't seem to be getting it.
Dear Mike, dear Greg,
you are absolutely the DP-Cracks!
The one thing with the microphone-permissions was finally the solution!
As i've seen there, a lot of my sound application did lost their permission (Kontakt, Sound Studio, etc.).
Seems to be OSX-Update-issue, i never got that problem before.
So many thanks and greetings from Switzerland,
Marc
Marc
Great! Glad you figured it out ! Best of luck to you
Re: DP 11 doesn't record (RESOLVED)
Dudes – just following up with this lingering issue (as of 12/23). This just saved me from the same dilemma. I had just switched to Sonoma, but didn't make the connection that a microphone security setting would mess up my DP setup. I tried my same Scarlett Solo in GarageBand and Audacity, and it was working, but not in projects I had fairly recently recorded in DP with the same setup. Man! Thanks for this.
DP11, iMac 27" 3.7Ghz 6-core i5 40GB, 1TB. User since Performer 3.
Some of these old threads are the gifts that keep on giving! Merry Christmas!
That’s why I rarely delete old threads. Often the end up helping someone.greg328 wrote:Some of these old threads are the gifts that keep on giving! Merry Christmas!
