CHOOSING A DEFAULT PATCH (SOUND)
The default patch is the sound that the track always
begins with. It is remembered when you save the
Digital Performer project so that the next time you
open the project and press play, the default patch is
called up from the synthesizer before playback
begins so that the track will play with the correct
sound. To select a default patch for a track, choose
it from the default patch column or menu.
The Patch column appears that the device needs to be initialized before it shows anything. So when you quit DP you must lose any init sent to the device and once you hit play again the entry should show.THE CURRENT PATCH
The Current Patch column in the Track List
displays the name of the currently selected patch
(sound) for the device that is assigned to the MIDI
track. If a patch has not been selected, no patch
name appears in the column. If you have patch
changes in the track, the Patch column will update
during playback to show the current patch.
PS - I think I remember why I put patch changes in the SE - I don't think the default patch in the TO is chased.
