M4 input noise?
tvbcristt
M4 input noise?
Post by tvbcristt »
Hi! I know that the two mic inputs provide quite a lot of gain, but I'd like to know if it's normal...in the image you can see that if I set the gain past 4 o'clock (and it is not crancked all the way up) there's a lot of noise coming from the input meters (and I can hear that in my DAW). This is happening as you can see with no mic connected but it's just the same with a xlr cable and mic inserted. Is it all good?? Does your M4 do the same? :roll:
My system is laptop HP zbook i7 with Windows 10.
Re: M4 input noise?
If I'm reading the switches and knobs correctly, you are seeing the input from your PC.
If that's not it, we need more information.
DP 11.32; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.6.1, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
CharlzS
Re: M4 input noise?
Post by CharlzS »
Try unchecking/disabling 'Use lowest latency safety' in the M4 control panel.
DP 11.32 PT 2024.6 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sonoma.7
tvbcristt
Re: M4 input noise?
Post by tvbcristt »
CharlzS wrote: Sun May 08, 2022 5:15 pm Try unchecking/disabling 'Use lowest latency safety' in the M4 control panel.
it's already unchecked.
tvbcristt
Re: M4 input noise?
Post by tvbcristt »
mikehalloran wrote: Sun May 08, 2022 3:45 pm If I'm reading the switches and knobs correctly, you are seeing the input from your PC.
nope, it's just the front inputs 1 & 2 level metering (apparently they work even with no cable/mic/instrument inserted).
Re: M4 input noise?
Does it anything change when you rotate the In/Out balance counterclockwise?
tvbcristt
Re: M4 input noise?
Post by tvbcristt »
mikehalloran wrote: Mon May 09, 2022 9:36 am Does it anything change when you rotate the In/Out balance counterclockwise?
doesn't change. and also doesn't change whether the MON button is on or off.
tvbcristt
Re: M4 input noise?
Post by tvbcristt »
I just contacted the Motu support via chat and they say it's just the regular noise floor of the unit....so it's normal :|
but I just wanted to compare with someone else's M4 here...
CharlzS
Re: M4 input noise?
Post by CharlzS »
I get one bar on the meter with the gain full tilt and quite a bit of noise in DP with a track record enabled for input one or two ~-48db. I also start to get noticeable noise just after a one o'clock setting, but nothing on the meters. That's with the output volume full on. In my previous post I misunderstood what was the issue.
tvbcristt
Re: M4 input noise?
Post by tvbcristt »
CharlzS wrote: Mon May 09, 2022 12:03 pm I get one bar on the meter with the gain full tilt and quite a bit of noise in DP with a track record enabled for input one or two ~-48db. I also start to get noticeable noise just after a one o'clock setting, but nothing on the meters. That's with the output volume full on. In my previous post I misunderstood what was the issue.
thanks :wink:
fernandezjw
Re: M4 input noise?
Post by fernandezjw »
If you plug 2 48V mics and turn them on, does the noise is still there ??
