Connecting Avid S3 via AVB to MOTU 16A
Maxxy
Post by Maxxy »
Hi there
I'm trying to connect a PT session which uses the Avid S3 desk in Studio B to my MOTU 16A in Studio A via AVB
MOTU Discovery doesn't see it and I don't know how to advise my colleague about how to set it up correctly there...
I believe I should be able to get this working... Shouldn't Discovery be able to see it? And then use MOTU Pro Audio Control to handle the received audio channels here?
Perhaps I need to make a Network Session in Audio MIDI Setup> MIDI window?
Any thoughts would be much appreciated
Cheers
Maxxy
Mac mini 2023 M2 Pro, 32g RAM, LG 32UD99 4k monitor on HDMI, OSX 13.6.1, DP 11.31, MOTU TB AVB 16A w/AVB Monitor 8 on ethernet cable, UAD Apollo x8, Netstor TB3 PCIe card expansion w/ UAD-2... 1 x Octo and 2 x Quad cards (not using much because I looove >), Softube Console 1 MkIII & Fader Control
Maxxy
Re: Connecting Avid S3 via AVB to MOTU 16A
Post by Maxxy »
Just to follow up.... it seems we need to use an AVB switcher ... pretty sure now that it's not possible with a direct connection
MOTU Discovery looks for 'MOTU AVB devices'... which the S3 is not... and Avid states that an AVB switch is required
So there it is... I will update if/when we make progress with this
Cheers and best
Maxxy
