Is there a way to assign a key to toggle the play button off and on, on a track you're recording on?
Scooter
Toggle play button off and on
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
Re: Toggle play button off and on
I assume you mean play enable, rather than play? Otherwise you would just tap the space bar. There is a play enable default key command you can find in the Commands window, and it can be reassigned. I don’t know that this would work when a track is in record mode — somewhere in the manual I recall reading that a track in record mode is automatically play enabled.
Yes I meant play enable. Thanks, I'll see if I can locate a way to do that in the Key Command window.
